I have ordered a Yank 2600 for my truck and have questions.
Ok as the heading reads.
My truck is a 1996 Chevy with a 305.
Is this converter a good choice????
I have read that people like the 3000 stall better, but they are mostly guys with 4.8's & 5.3's.
Is the 2600 a better choice for the older trucks, due to the much lower powerband?
Is there anyone on here with a OBS that uses this converter that can give me their opinion????
Thanks for the help,
Bruno
Bruno
My truck is basically stock, other than when it needed a part, I usually upgrade to something better.
Only thing other than stock is:
Exhaust-Replaced it all 3" ,no cat, Dynomax ultra flow, mandrall bent tail pipe.
Rear axle-Repalced Diff with Detroit Tru Trac, Richmond 3.42 Gear
And now I have a FLT level 3 4L60-E, and a Yank 2600 converter on the way.
I figured once I get the trans & converter in I'll go for a dyno tune, and have the torque management removed, and have the tune optimized.
So that converter was a good choice?
13 Second Truck Club
When I had mine dynoed(same design, Gen 1 except 4.3) torque really started climbing around 2400-2500, so a 2600 should put you right in a good spot. We I swap in a converter, thats what Im going to buy.
It added 73hp and 108ft.lbs. to the N/A numbers.
