Hydroboost Conversion, how to with pics
Old 09-26-2016, 01:04 PM
  #151
diggy79's Avatar
Just wanting to confirm after reading this thread, that i can upgrade my 2000 to hydro-boost with a 2wd rack and Pinon?
i see some rack and pinon guys chimed in but no official "yes". i have swapped the entire hydro-setup, petal, etc... from a 2005 2500HD duramax, but i have no lines hooked up yet. i have all the rack and pinon lines as well as all the steering box lines, cooler lines everything from the donor.
Old 09-26-2016, 01:13 PM
  #152
I have a gauge for that
Atomic's Avatar
If all the lines fit you should be good to go!
Old 09-26-2016, 01:50 PM
  #153
Jake75's Avatar
yes i just did mine no problems i also had a cooler and rack and pinion
Old 01-23-2018, 03:52 PM
  #154
Fullpower's Avatar
Originally Posted by gmcswb199
whats a hydroboost doooo???
HydroBoost stops you with a quickness.
Also, the HydroBoost will work without any Manifold Vacuum, which can get scarce under boost.
Old 06-15-2018, 07:44 PM
  #155
Fast lane preferred
meatwad's Avatar
Can anyone confirm the current hydroboost pedal and pump part number. The original ones are no longer valid.
I have found these:
pedal 15906966
pump 15909826
Remans for that pump part # by cardone are $46 with a $40 rebate on amazon right now ( net $6?!) Pedal is still around $20 on gmpartsdirect if correct.
Old 06-16-2018, 09:16 PM
  #156
Custm2500's Rude Friend
1FastBrick's Avatar
I have found these:
pedal 15906966
pump 15909826
That is the pedal.
That is the Pump.
Reman's are a 50-50 shot... best of luck.
Might be cheaper to get the pedal from amazon or ebay. GM Parts Direct has terrible customer service and there mark up on shipping is ridiculous...
It's not that the factory pump doesn't work, It's that the resivor has a 3rd port on it. The resivor is not sold separately. Other option is to T into the return line.
Old 06-16-2018, 10:50 PM
  #157
GMCtrk's Avatar
I Tee'd mine and used the factory PS pump. 2wd rack and pinion.
Old 06-17-2018, 04:43 PM
  #158
Fast lane preferred
meatwad's Avatar
Cool. Just wanted to make sure about the part numbers. I will do this at some point. My pump has almost 200k miles on it, and is making a little noise. Probably get one off eBay if the remanufactured ones are suspect.
Old 06-26-2018, 02:41 AM
  #159
adriver's Avatar
I have found these:
pedal 15906966
pump 15909826
I didn't look up your part numbers, but there is a hydroboost pump for the 99-02 and a different one for the 03+ (don't know what year up to).. What year is yours?
Old 06-27-2018, 01:23 AM
  #160
Fast lane preferred
meatwad's Avatar
My truck is a 2003 silvy ss with the original power steering pump and vacuum assist.
Part numbers I referenced are for the power steering pump and not the hydroboost itself. I think they work for 04 and up HD trucks and maybe Tahoe’s.
Quick Reply: Hydroboost Conversion, how to with pics
