How wide?
Hey guys,
I have decided I'm going to pick up a rcsb to replace my HD for a play truck.
I plan to do a 4/6 drop on it but I also want to put as wide of a tire under the rear as I can. I would like to run 315/35/20 NT05's on it, I have searched a bit and have only seen two trucks that had this size tire, and I was hoping somebody could assure me that this size will fit in the rear of a NBS with a 4/6 drop.
Thanks
Kody
Thanks
Kody
I don't see it being a problem either, from what I have seen with a 4/6 the fender is still above the tire. Plus I plan to roll/cut the lip down on the rear so I should have some room, But I just want to make sure.
Thanks
Kody
Fender being above the tire depends on tire height. With 275/35/20s, I had about 1-1.5" of clearance. Those tires are 28.6 so your gonna be close to tucking. Like said though, get the proper backspacing and you should be fine.
thompson
Dec 27, 2017 06:48 AM
Lamartian92
Sep 10, 2015 09:27 PM
