How reliable are aftermarket gears?
Old Jan 9, 2010 | 03:20 PM
illMATTic's Avatar
Default How reliable are aftermarket gears?
I want to change out my gears but am worried about how long they will last. I drive this 07 daily and will never see the track. I also tow about 3000# on weekend trips.
I see these ring & pinion sets for 200 bucks or so. How long do they last?
Old Jan 9, 2010 | 03:49 PM
black00chev's Avatar
Slowest turbo build ever!
As long as you go with a well known gear company you will be just fine. Most importantly you or whoever will be installing them needs to set them up correctly. Too much or too little backlash and preload will cause bad wear patterns and if not contacting each other enough can easily chew the teeth.
Old Jan 9, 2010 | 08:11 PM
Coban's Avatar
As mentioned above, the install is typically what makes or breaks gears.
Brands that quite a few people used are AAM (basically OEM replacement), Yukon, and Motive. I personally had really good luck with Motive.
Old Jan 9, 2010 | 08:13 PM
GMCtrk's Avatar
I would not use anything except AAM. It's only marginally more expensive (4.10s are $200 from Ron)
Old Jan 9, 2010 | 08:16 PM
charcoal03silvy's Avatar
Stay away from Spider gears, my cousin broke 2 sets, he switched to Motives i think and hasn't had a problem.
Old Jan 9, 2010 | 08:25 PM
00ChevyScott's Avatar
Wearin' da big hat
Spider gears the smaller ones in open diff axles.
Here's the 2nd (of 3) I broke in my truck
Old Jan 9, 2010 | 08:40 PM
He said the company was spider
Probably why I'd never heard of the company though.....
Anyways, he loves his motives
Old Jan 9, 2010 | 11:47 PM
ap2002's Avatar
i have yukon 4.11 years since 2005/2006 with probably 200passes at the track and have zero issues....
Old Jan 11, 2010 | 06:23 PM
illMATTic's Avatar
Thanks, I'll have to look into a set soon.
Old Jan 11, 2010 | 06:58 PM
viciousknid's Avatar
Where's the Beef?
Motives are good. I broke a set of cheaper gears and they whined up until they broke. The Motives haven't made a single peep
