How much Trans P.S.I. ????
Old Sep 18, 2006 | 11:57 AM
Default How much Trans P.S.I. ????
How much trans PSI for a FLT 4L65E. I looking for max in any gear. I'm asking because when I pulled the engine and tranny I had to cut the hard lines cause they where big time stuck on the tranny and the factory trans cooler broke when trying to remove the lines. Any ways I am looking to do the Aeroquip -an fittings and the socketless hose but the hose is rated for 350 PSI so I just wanted to make sure i buy the right stuff so I can run my tranny lines and install the new cooler. Thanks for the help in advance.
Danny
Old Sep 18, 2006 | 01:20 PM
litreddevil's Avatar
Banned
you will be fine
Old Sep 18, 2006 | 01:22 PM
Derek @ EDO's Avatar
FormerVendor
i would think you would be fine with the 350psi line.
Old Sep 18, 2006 | 02:47 PM
Cool thanks guys.....
Old Sep 19, 2006 | 09:51 AM
FLT's Avatar
FLT
FormerVendor
Your trans at max line pressure in lockup should make 100-120psi and pump about 1.5- 2+ gallons a minute. Or at least that is what I see on the picture in my sig.
Last edited by FLT; Sep 19, 2006 at 02:57 PM. Reason: Had to re-dyno to verify info
Texas5.3_1251
Mar 5, 2016 08:10 PM
CammedZ71
11
Sep 9, 2015 02:05 PM
11MPG
Sep 8, 2015 04:52 AM
Mark_k
Sep 7, 2015 10:15 PM
MadDMax66
Sep 5, 2015 01:27 AM
