How much shift delay do you have??
Old Feb 14, 2009 | 03:11 PM
12sec.5.3's Avatar
Default How much shift delay do you have??
Looking at my log files my pcm commands a shift at the "set" shift point but the trans isn't shifting till maybe 200-400 rpms later. Is this normal? I would think not...
Old Feb 14, 2009 | 05:11 PM
02gmcbandit's Avatar
not sure about this cause i had my tuned by Doc of Efi Alchemy. mine shifts dead on 6000 everytime which is what its set for, not before or after. i think they call it "zeroing out" the shift time.
Old Feb 14, 2009 | 05:13 PM
blackbeast ss's Avatar
mine are zeroed out
Old Feb 14, 2009 | 05:14 PM
thats not your shift times, lower your mph on your shifts if it is shifting too late
Old Feb 14, 2009 | 05:22 PM
12sec.5.3's Avatar
Lowered my shift by vss from 84 to 83 but it was holding till almost 90
Old Feb 14, 2009 | 05:46 PM
how many gears shift as per your tune? which one is the one your having issues with?
Old Feb 14, 2009 | 05:52 PM
12sec.5.3's Avatar
2-3. Have to wait until I go to the track to check out the 1-2.
Old Feb 14, 2009 | 05:57 PM
viciousknid's Avatar
Where's the Beef?
you can't check 1-2 on the street?
Old Feb 14, 2009 | 06:04 PM
12sec.5.3's Avatar
Nah, it roasts the tires and hits the rev limiter a few times before the shift. Well, I probably could see when it's commanding the shift and when it's actually shifting, but I would think it would be more accurate with traction.
Old Apr 13, 2009 | 04:54 PM
03tahoe22's Avatar
1-2 shift is strong on mine but 2-3 shift is delayed and doesnt kick in.... I have a shift kit. Is this a common problem? Any solution to your problem? sounds similar.....
