How much grinding is required ?
Old Aug 19, 2012 | 09:28 AM
03LQ9's Avatar
Default How much grinding is required ?
I need to get a pair of sticky tires on the back of my truck. Seems there are a few different ways of going about it to run a 15 wheel. With the stock calipers on an 03 truck how much do you have to remove from the rear calipers, 1/4 in, 3/8 or more ?
I read that going to s10 calipers you still have to grind but how much less ?
I have a big grinder and some time so should I just stick with the stock calipers and grind away ?
I don't know, maybe I should just stick with a 16in and run that.
Thanks for any info!
Old Aug 19, 2012 | 01:57 PM
boosted_blue's Avatar
Personally, I wouldn't grind anything off of a caliper. Your best bet for reliability is to either swap to rear drums or just run a 16. Taking that much off of these calipers to fit a 15 is an accident waiting to happen being that they are cast.
Old Aug 19, 2012 | 02:06 PM
quicksilverado's Avatar
It is no big deal to grind the calipers.
Old Aug 20, 2012 | 12:10 PM
Do it right the first time so it's not a headache later on down the road and you're not constantly worrying about it. Taking that much material off of the calipers and being that that they are cast only makes it a matter of time. I've seen it happen when brake boosting or when when running a hydro boost setup. Too many people cutting corners these days and calling it a "budget build" but sacrificing their reliability. From taking off brakes for weight reduction to completely hacking what was a nice vehicle to **** and calling it a drag truck. It's pathetic and dangerous. Just save up the $ and do it right...but if you do feel like grinding swap to an s10 rear caliper. IIRC they require less grinding to fit and would possibly be more reliable because of that, only downfall is the pistons are smaller and you would probably see an increase in the distance it requires to stop
Old Aug 20, 2012 | 07:19 PM
I did it 5 years ago and have had no issues. Have put about 175k miles on it since grinding the calipers.
Old Aug 20, 2012 | 08:05 PM
https://www.performancetrucks.net/fo...d.php?t=506415
Old Aug 21, 2012 | 08:42 AM
Johnmaster's Avatar
MASS seller approved
x2
Old Aug 21, 2012 | 09:01 AM
banker099's Avatar
mine are ground down...about a year now...no problems
Old Aug 21, 2012 | 12:23 PM
Johnmaster's Avatar
The bigger problem is that if you get wheels with a high backspacing so they don't stick out past the wheelwells, you run right into the brake line. On a lifted 4wd this isnt a problem but on a lowered truck you need to get that tire into the well. The only way I thought to remedy it was to weld up and drill and tap the back of the caliper to get the line out of the way. Lots of work when all I needed was a custom bracket and the calipers/pad/rotors off a 90 chevy front...
Old Aug 21, 2012 | 06:30 PM
blown02408's Avatar
02 w/ lowest mileage 2800
99-02 calipers are ok to grind; 03 and up are not, you have to remove too much material.
thompson
Dec 27, 2017 06:48 AM
hodge9386
Oct 25, 2015 01:26 PM
alex226
Oct 14, 2015 07:23 AM
03sierraslt
14
Oct 9, 2015 05:53 AM
twake_410
Sep 25, 2015 10:09 PM
