How much did your 4l80 swap cost?
Old Jun 23, 2015 | 07:46 PM
TheBeeblebrox's Avatar
A little over 5k for my set up all said and done, Jake's stage 2 trans and a Circle D triple disk converter, I'm 2wd so I didn't have to deal with driveshafts/input shaft.
Old Jun 23, 2015 | 08:09 PM
Suburbazine's Avatar
My setup was a little over $6K all said and done. The billet stuff is expensive.
Old Jun 23, 2015 | 08:34 PM
03sierraslt's Avatar
Originally Posted by 2002_Z28_Six_Speed
I really thought about going your route with the TVS2300 because I had one on my G8 GXP. Did you have to swap to rectangular heads or did you use a different adapter plate for the TVS? Where did you get the input shaft and how does the truck run with the AWD? (I have almost same vehicle, here).
I'd love to see some pics of that beauty!
Cathedral port 2300. The AWD is great, only spins if I get on it hard.
Old Jun 23, 2015 | 08:46 PM
dirt track racer 81's Avatar
Stock 95' 4l80e off craigslist I picked up for $250
Fti nitrous converter was $832 shipped.
I know the guy that builds the crossmbers so that was free lol
Wiring I did myself.
Yoke was $80 off eBay.
Truck went 10.64 and that trans lasted 3-4 years
Old Jun 24, 2015 | 07:51 PM
Fast355's Avatar
About $1200 by the time I included seals, pan gasket, filter, fluid, flexplate, plate steel to modify the crossmember, shift cable, new yoke, new Spicer solids, cutting the drive shaft and another $300 to put in an extra trans cooler and plumb both coolers.
Old Jun 25, 2015 | 09:49 AM
shorty's garage's Avatar
transmission, yoke, plate, spacer $80
Fluid and filter$50
sfi plate, bolts $200
Pat 4" driveshaft $400
Trans cooler, lines $150
Dipstick $75
Old Jun 25, 2015 | 10:59 AM
06 4.8's Avatar
If your sig is current why do the 80e? A built 60 will handle your power just fine and the gearing on the 60 will be a lot better for the mods.
Old Jun 25, 2015 | 12:02 PM
Fast355's Avatar
No offense the 4L60E is a POS and always will be. The 4L80E lives a much longer life and will handle has setup STOCK! The first 60E in my Express died at 38K behind a stock 255 hp 350. The second was a 4L65E spec build that died at 78K. The 110K mile Junkyard 4L80E shifts so much nicer than the 60E or 65E ever thought about. My moded 350 has no problem breaking loose the 255/70R15s on said 6,200 lbs Express and I am only running 3.73s.
Old Jun 25, 2015 | 01:45 PM
natejk's Avatar
8 Second Truck Club
$1900 built trans with including core
$650 covnverter
$425 driveshaft
$90 1350 pinion yoke
$150 crossmember
$150 harness(would just wire myself now)
$200 deep pan
$75 trans lines
$80 lokar dipstick
$30 poly mount
$3750
Old Jun 25, 2015 | 02:12 PM
GM1697's Avatar
Sig isn't current, she's got a cam now, I gotta update that.
And boost is in the future.
