How high of a stall
Old Sep 23, 2006 | 10:37 PM
6.0caddy's Avatar
Default How high of a stall
I just want your 2 cents about a stall. I am getting a fuddle TC thanks to 1slowz71, and I was going to stall it at 3500. My mods are below. I launch in 4 hi tracion is not a problem. This is my DD so got to keep it drivable. Is 3500 good? higher or lower?
Old Sep 23, 2006 | 10:41 PM
v8
17,16,15,14,13,12,11 Drvr
well with the 3500 stall converter your not going to start moving untill 2500rpms, so your intown gas milage is going to sux. for a DD I wouldn't go more than 2500-2800 good luck.
Old Sep 23, 2006 | 10:52 PM
1SlowHoe's Avatar
Destroyer of Transmissions
Ummm, 3500 would be for a strip only truck IMO. You need to look for something in the 2600-3000 range. Remember this is the flash rate. If you are at a stop and floor it, the converter is going to let the engine free spin until 3500rpm before you start moving. And with a 3500, you will get traction issues. I have a 5600lb Tahoe, a 2600 Fuddle stall. If I nail it from a stop, all I get is tire spin. I have 24" rims which = HEAVY, they just spin and spin until I let out. I also have a Radix but, I still think 2600 would be good for you. 3000 is the biggest I would go for a DD.
Old Sep 23, 2006 | 10:53 PM
storm5.3's Avatar
13 Second Truck Club
2800-3200 would still be streetable..
Old Sep 23, 2006 | 11:36 PM
i have a 3200 that will flash to 3400ish and its a DD, i would ask for 3500 though personally. especially with your mods and the application it appears its going to. stick between 2800-3200
Old Sep 23, 2006 | 11:59 PM
6.0caddy's Avatar
Well be putting heads and cam later too. I'm thinking 3200 now.
Old Sep 24, 2006 | 12:02 AM
ZR1 DREAMING's Avatar
mine is fine with me and it's my DD!
Old Sep 24, 2006 | 12:09 AM
6.0caddy's Avatar
i yours a 4000?
Old Sep 24, 2006 | 12:12 AM
Originally Posted by 6.0caddy
i yours a 4000?
Yes, link to mods in sig. Yank SS4000.
Old Sep 24, 2006 | 12:19 AM
6.0caddy's Avatar
everybody is tell me to stay with no higher than a 3200. What rpm does you truck start to move?
