How far will a shift kit take you?
9 Second Truck Club
How far will a **** kit, and servo take you on an stock 03 4L60 in a RC, 4x4 ? 1/4 mile times& RWHP. Is high 12's too much to ask? I have a built 4L80E, but my truck only has 3.42 gears
. I know when I change the trans I will need a gear chang also
I have a T66 Trick front mount, and would like to run about 10-12LBS(@ high altitude) on the stock 5.3 for a few months. Then when I get the 6.0 finished I want to do the trans, and gear swap. I just don't wan't the trans to take a **** rite away. Any suggestions? Thanks, J
It really depends on your trans. Some trans won't last long running 12s (hell even stock), but others will last a long time. It will be good for 12s, but who knows how long it will last.
Finally had a problem with mine, pushed the front seal out due to something seizing at the pump cover area (I'm not a tranny guy). BUT I did hammer the **** out of it...about ten runs back to back, every few minutes, stalling for probably too long to build boost WAY past what the converter will normally stall at. If I had even just driven it hard and not beat the crap out of it, I am told it probably would have been perfectly fine. I'll probably go 80e next year after I get my 7's this season.
9 Second Truck Club
After seeing how good yours shifts, Im thinking about giving the 60E a try. My truck does have 130k on it though. Still shifts good, and has never towed anything. I just don't have the time, or the $$$ to swap the gears, and trans rite now. Need to be heading back to C/springs by the end of next week.
lycominghunter
Aug 15, 2015 12:26 PM
zaathur151
Jul 6, 2015 10:57 PM
