High speed vibration
Old Apr 23, 2009 | 08:43 PM
  #31
GMCtrk's Avatar
I'd say a steel 2 piece DS is the way to go if you're going to get it custom done. GM got it right with the steel 2 piece on the ecsb trucks. Mine's been to 120 the other day smooth as silk.
Old Apr 25, 2009 | 07:04 AM
  #32
I looked into this and it's a no go for the new body style. The 2500 HD has it but the cross member is built into the frame!!! Also the frames are different between the HD and 1500. I looked to see if I could fab one up but you just don't have the room for it.
I do agree with you on this and the set up looked nice on the HD.
GM should have left a good thing alone with the two piece set up for the ECabs
Old Apr 25, 2009 | 07:52 AM
  #33
Dark Halo's Avatar
my scsb 02 has a bad vib between 70-75 and my CC 06 is above 95 like you guys. One thing in common is both have been lowered. My scsb has a custom built high speed drive shaft from speed eng (I have converted to an 4l80e). I am swaping gears and will be checking pinion angle tomorrow and let you guys know how it goes from there.
Old Apr 25, 2009 | 12:51 PM
  #34
slow.8's Avatar
well, this has been encouraging. might as well leave the damn speed limiter on. my truck has a 3/5 drop. steel drive shaft, and no pinion shims to my knowledge. i havent experienced any vibration so far. i had a tune planned in the future, but why bother. these trucks seem to turn into money pits when you start modding them.
Old May 2, 2009 | 12:43 PM
  #35
three83's Avatar
I have the same vibration after 90mph since the day I bought my truck. I've tried everything besides getting the drive shaft balanced. For now, I just don't drive over 90mph, when I have my TrueTrac and 4.10s installed, I'll have the drive shaft balanced then. I will need to get it done before any other mods because I'm at 91mph in the 1/4. I sure wouldn't want to sling a drive shaft at 90+mph. I'm even thinking of installing a drive shaft loop.
Texas5.3_1251
Mar 5, 2016 08:10 PM
FlyingLow
Nov 24, 2015 10:05 AM
dantheman1540
Sep 15, 2015 08:28 PM
dhorner77
Sep 11, 2015 05:10 PM
bisqikss
Sep 8, 2015 03:35 AM
