HELP, Tranny temp!!
Old Dec 20, 2005 | 12:53 AM
02gmcwaldoch's Avatar
Would you guys recommend getting a bigger tranny cooler for the TB stall or will the stock cooler work?
Jesse
Old Dec 20, 2005 | 02:32 AM
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
I would get a 15K cooler or something close to that I have heard some people have cooling issues in the summer oyu probably wont righ tnow but when it gets hotter you may run into problems.
Old Dec 20, 2005 | 08:26 AM
OnyxSilveradoSS's Avatar
we have talked about this over @silveradoss.com
I have the shift kit, tb tc and I put the Bm supercooler on, and my trans temps are low.
the cooler is just for the summer, and is nice b/c is varies the flow for how cold the fluid is. I think the best way to tow was in 3rd- so you dont lock up the converter and heat it up too much.
oh yea I put a 160 stat which should lower your trans temps some too...
I was worried about my temp too, but when it is 20 out I will have to wait for the summer to check if it stays cool.
Old Dec 22, 2005 | 08:59 AM
gonzo 6.2's Avatar
Info:
The trans /converter is designed to apply in 2nd,3rd,and 4th gear.Also the fact is the trans stays cooler with the converter locked up/applied.
Old Dec 22, 2005 | 10:43 AM
Wilde Racing's Avatar
How do I change this text
Yep Locked TCC=cooler oil
Old Dec 23, 2005 | 02:35 AM
sikchevy's Avatar
i thought the same thing when i put in the esky cluster cause at first the temp didnt move, but after a few miles it started to rise.
Wolftrk99
Dec 3, 2015 08:12 PM
JordanH
Oct 3, 2015 03:59 PM
sTNT971
Sep 26, 2015 06:27 AM
kmcn47
Sep 17, 2015 01:12 AM
mayko
Sep 7, 2015 12:24 PM
