HELP, Tranny temp!!
Old Dec 19, 2005 | 03:57 PM
02gmcwaldoch's Avatar
Default HELP, Tranny temp!!
I just recently installed my transgo shift kit, vette servo, and tranny temp gauge, and my tranny temp gets to a max of 150* and thats only when im really gettin on it for a while? Is this normal? or is it low?
Jesse
Old Dec 19, 2005 | 04:24 PM
gonzo 6.2's Avatar
Where is the sensor located? Sounds normal in cold temps,how does the trans work?
Old Dec 19, 2005 | 04:46 PM
Bish's Avatar
I'd say normal. Mine rarely get's above 150 in winter. Runs hotter in summer (185ish) but never goes above 200 in summer.
Old Dec 19, 2005 | 06:03 PM
sensor is located in the pressure test plug. The trans works just fine. I just got kinda scared when people were saying it should run at 180*! I have a factory tranny cooler if that makes a differance plus it only like 20* outside here. So would that be considerd normal for this weather?
Old Dec 19, 2005 | 06:19 PM
gonzo 6.2's Avatar
Doing a shift kit wont make your trans run cold,even if you did something wrong which it sounds like you did an excellent job. Did you have help? did you have any issues or problems that left you wondering if it was right?
Old Dec 19, 2005 | 06:37 PM
KySilverado's Avatar
I'd call it normal
Old Dec 19, 2005 | 08:45 PM
gonzo6.0- i had some help from a friend who worked at a tranny shop, and we never doubted anything during the install. I installed the gauge right after the shift kit and servo. I figured i hooked it up wrong, but after a while it went to 150*.
Jesse
Old Dec 19, 2005 | 09:23 PM
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
Yeah that sounds fine in your weather. Dont wrry 140-210 is a good operating range.
Old Dec 19, 2005 | 09:35 PM
bluecajun5.3's Avatar
11 Second Truck Club
you should be fine man...
Old Dec 20, 2005 | 12:52 AM
thanks a lot guys!!
