Help picking a converter
Old Aug 27, 2007 | 07:41 AM
slowec's Avatar
Default Help picking a converter
I need a converter to go with my Lvl 5 in my sts 6.0 truck. The problem is I bought a Z28 and the verter needs to be able to tow the camaro. The problem is I can't build any boost at the line
Also, what parts swap over from cars to trucks as far as trans missions goes. I got alot of parts floatin around the garage.
Thanks in advance for any help.
Old Aug 27, 2007 | 08:59 AM
nonnieselman's Avatar
Iv i were you i would go with either the Yank Truck Thruster 2600 or 3000.
IVe got the 3000 and i love it.. and ive towed a decent amount with it..
Old Aug 27, 2007 | 09:03 AM
silver-mod-o's Avatar
Hunt&Fisherator
Yank SS3200 IMO... tight converter, will still probably let you get into boost, and plenty strong to tow with... make sure you run a hefty cooler with it.
Old Aug 27, 2007 | 09:27 AM
Grumpy5.3's Avatar
are you supposed to tow with the SS series vertors??? I knwo you can with the TTs.
Old Aug 27, 2007 | 09:30 AM
Hunt&Fisherator
I've towed a 4WD duramax CCLB dually with my SS3600.... no problems, just watch the heat.
Old Aug 27, 2007 | 10:23 AM
slowec's Avatar
Does a ls1 camaro and 00 p/up use the same converter?
Old Aug 27, 2007 | 10:29 AM
Hunt&Fisherator
yep... I have a f-bod converter in mine.
Old Aug 27, 2007 | 02:05 PM
bluecajun5.3's Avatar
11 Second Truck Club
not with your truck low like it is.
Old Aug 27, 2007 | 02:13 PM
ZR1 DREAMING's Avatar
I bet it wasn't on a trailer, just rolling behind it... Ben doesn't have a hitch.
And BTW, stick with the TT series for towing
Old Aug 27, 2007 | 02:26 PM
ok that makes better sense now.
rodney. like i told you put the level 5 and vig in the maro.
if you still want a converter for the truck go with the tt3000. that's what i'm going to go with when i start haulin the chevelle.
