Help new 4l80e is in now truck wont start
Old Feb 18, 2012 | 08:37 PM
phasemaster1's Avatar
Check the plug at transmission I had mine in wrong.
Old Feb 18, 2012 | 08:41 PM
chris092183's Avatar
Vince and Silvermodo I tried both of those...still no start
Old Feb 18, 2012 | 08:43 PM
could it be internal wiring? what if the nss got wt with trans fluid?
Old Feb 18, 2012 | 08:53 PM
which one the vss or iss sensors?
Old Feb 18, 2012 | 09:02 PM
Or are you talking about the round connector? If so is which way should the pigtail be facing. I was thinking when originally had the round connector on my other 80e it was facing the rear now this time it is facing forward. It seemed that that was the only way it would go.
Old Feb 20, 2012 | 04:12 PM
Could I hook a scanner up to the truck and possibly find the root of the problem?
Old Feb 20, 2012 | 05:47 PM
Vince B's Avatar
I would not think that internal wiring could be an issue because it is used for the solenoids and really has nothing to do with starting the truck. Hell unplug it and see if the truck starts?
The rear is the for VSS and the front is the ISS or turbine.
If you look at the main harness plug and the case connector there is a "key way" so to speak that only allows it to be plugged in one way. I still do not think this is your issue.
Old Feb 20, 2012 | 08:26 PM
I will try unplugging the nss tomorrow.
Regarding the ISS and VSS. I retained the old 65e vehicle speed sensor connector for the rear and the new connector i added up front for the Input so I know the speed sensors are correct.
Ok thanks for clearing the case connector up.
You are the man Vince I appreciate your input.
So I guess I can rule out the case connector.
I remember a while back when the wiring I did for the new iss came undone and I had these same symptoms. I simply reconnected the wiring and it fixed the issue. I checked for this problem again and no luck.
I read somewhere about "grounding the prndl switch". this is in the same black box as the nss right? How would you go about doing this anyway?
Old Feb 20, 2012 | 09:23 PM
Vince B's Avatar
When I said to unplug the harness to see if the truck starts I was talking about the main case connector for the internal wiring for the trans. Like I said I do not think your issue is there. Yes the NSS or the PRNDL is the black box on the side of the trans. This where I think your issue is at or the wiring for it. I do not know what you are talking about grounding the switch. I guess where ever you got this info you should ask there. If I had to guess they are grounding a wire that will complete a connection for park or neutral if I had to guess.
Old Feb 20, 2012 | 09:49 PM
JFOLM's Avatar
The clip on the cable is broke on mine and will not let me go into park sometimes.
Maybe we are passed this but do you have all your grounds connected?
Have you tried to manually (at the lever on the trans) put it in Park or Neutral to start it?
