Help me make my truck hook
Old Jul 28, 2015 | 01:43 PM
  #21
George C....'s Avatar
Formerly ScreamingL
Stock suspension section...it's a sticky
Old Jul 28, 2015 | 02:32 PM
  #22
dubwise's Avatar
read the thread on yellowbullet. it will set you with a starting point.
I browsed through it in the past. No doubt it has some good info in there. A lot of the cars in there seemed to be running 9s and cutting 1.3 60's who needed advice.
I was looking for something more orientated towards 10, 11, 12sec nose heavy trucks like "my truck worked best on 4 clicks off full tight rebound and full tight compression in rear". I realize the answer is probably whatever works best for my setup.
The last time I went to the track I was only able to get 4 runs in in 4 hrs and out of the 4, 3 of them I spun (with 4 clicks from full lose rebound and full tight compression). I was hoping to fast track some of the TNT, but maybe it is unavoidable.
Next time I'll try full tight rebound and work it from there.
Old Jul 28, 2015 | 02:40 PM
  #23
Formerly ScreamingL
Read the tread again and read more then 2 pages...all your answer for a truck is there
Hell read deep enough and you'll see posts about full-size trucks
Old Jul 28, 2015 | 06:45 PM
  #24
Gadgetized's Avatar
My truck has exactly 5" of travel if I jack the front end up where the wheel is just off the ground.
Old Jul 28, 2015 | 06:52 PM
  #25
Formerly ScreamingL
Measure shock at ride height and then at full extension
If you have more then 5 you're good
Old Jul 28, 2015 | 07:39 PM
  #26
Gadgetized's Avatar
When I pulled it in the shop at the wheel well above the center of the tire it was 31 1/4 above the drivers side, and 31 3/4 above the passenger side. When I jacked it up to the tire just touching the ground it was 36 1/4 on the drivers side and 36 1/2 on the passengers side.
Old Jul 28, 2015 | 07:47 PM
  #27
Formerly ScreamingL
My truck is 27.5 ride height and 36" extended
Old Jul 28, 2015 | 09:37 PM
  #28
Gadgetized's Avatar
If I went with a coil over setup in the front do you think it would give me that much? What is your setup?
Old Jul 28, 2015 | 09:45 PM
  #29
Formerly ScreamingL
I would have more if it wasn't for my upper ball joint being maxed out
JDM drag springs, stock limiters trimmed back some under upper control arms
Pics in my build thread
Old Jul 28, 2015 | 09:56 PM
  #30
TXsilverado's Avatar
sounds like you have enough travel. I wouldn't worry unless you start topping out your front suspension (and if the rear unloads when it tops out)
