Help, Gear Whine...After New Setup
Old Mar 2, 2019 | 10:17 PM
Weagle1's Avatar
Default Help, Gear Whine...After New Setup
I installed a used set of gears and Eaton posi. I have a irregular howl under 40 on acceleration and deceleration. When turning right at speeds above 20 I get a solid howl/whine. What could have gone wrong, I read the pattern as the below. Any suggestions?
Old Mar 2, 2019 | 10:29 PM
RySmDPT14's Avatar
Recheck the backlash and pinion depth, hearbpattern needs to be checked with differential under load (parking brake or manual resistance) with used gears it’s more important to check the coast side and not drive side patterns. What brand gears?
Old Mar 3, 2019 | 06:39 AM
Weagle1's Avatar
Yukon gear set, backlash was at .004 preload at 19in lb. When I checked my pattern I did not do it under load, so I bet the depth is off. Thank you
Old Mar 3, 2019 | 07:22 AM
smokeshow's Avatar
Mod with training wheels
If you don't test it how you intend to drive it, how do you expect it to drive how you tested it?
Old Mar 3, 2019 | 09:21 AM
Weagle1's Avatar
Tested, just not under load see above applying braking , thanks/no thanks for your help.
Old Mar 3, 2019 | 05:34 PM
RySmDPT14's Avatar
Hope you get it sorted out. I’ve always had best luck with motive gears. Randy’s rib and pinion is also a valuable source to go to for information. Did you happen to do the solid spacer or crush sleeve?
Old Mar 4, 2019 | 05:24 PM
Weagle1's Avatar
Using crush a crush sleeve, pattern as it was:
Old Mar 4, 2019 | 05:35 PM
RySmDPT14's Avatar
I would like to see the drive side more centered and the coast looks like it is favoring the toe a lot (based on first tooth pattern I can see)
Old Mar 4, 2019 | 07:03 PM
Weagle1's Avatar
I’m I reading this right as in the pinion is still too deep?
Old Mar 4, 2019 | 07:05 PM
Weagle1's Avatar
Drive side
