HELP-found that rubbing noise
Old Feb 17, 2007 | 06:00 PM
9GMC9's Avatar
Default HELP-found that rubbing noise
-Sorry for being long-
Today I took a look at my truck and found that rubbing/thumping noise that it made when in 4X4. CHECK IT OUT(This is the front driver's side wheel location)
The bolts are grinding. I took a look and cant see anything that has moved. DOES ANYONE know what could have slipped, its eatin' up my tire too!
Old Feb 17, 2007 | 06:04 PM
gao8302's Avatar
Yeah mine did that when i got it and by the time i figured it out it stopped making the noise. My half shaft slipped out a little. Make sure it goes all the way in. It should snap when its in. If it worked its way out some. And by the way when mine did that it didnt hurt anything.
Old Feb 17, 2007 | 06:18 PM
9GMC9's Avatar
Didnt hurt anything? Well thats not a good thing, its eating up my tire and giving me some shitty gas milage, plus when I brake the whole front end shakes lika a muah ******.
Old Feb 18, 2007 | 07:59 AM
KySilverado's Avatar
Maybe the front diff has moved? Its located with isolation rubber bushings. I'd have a look at them.
Old Feb 18, 2007 | 05:38 PM
Tahoe6.0's Avatar
see if the hub flange from the diff is loose, bearing could be worn. Also like someone else said (check diff carrier housing bushings for wear. They should never wear only if they were loose from a previous R&R and not tightend. Good luck and let us know what you find.
Old Feb 19, 2007 | 09:11 PM
9GMC9's Avatar
Thanks for all the info fellas! I think a allignment might do the trick(Well at least I hope).! We'll see whats up soon!
lukn4trbl355
Oct 21, 2015 11:19 PM
turbo6c3
Oct 5, 2015 06:11 PM
Infernohoe
48
Oct 2, 2015 10:25 PM
Velocity1
Oct 2, 2015 08:01 AM
tim wellington
Sep 29, 2015 10:17 PM
