Help! ASAP
i have a 2005 gmc sierra 1/2 ton 2wd changing rear ends. its not the c clip style like the old chevys. how do you remove the axles. anyone have any info. would be very helpfull. thanks!
You have to remove a 8mm bolt that locks a big rod/pin in, in the middle os the carried between the spider gears. remove the pin and push the axles together and then you can get the c-clips to fall out or grab them with a magnet.
^^is how mine was I don't think they have change, but i dunno.
hope this helps
Thats how mine was...
hope this helps
hope this helps
you have to pull out that center large pin.... you take the small bolt out that retins it... then the large steel pin... then you should be able to push the axles inward, then you drop the c clips then pull them out a lil, and mr carrier will be just about ready to come out as soon as you take the caps off...
and dont forget to check your backlash
