Hd2 kit plus dual feed mod ok?
Old Apr 7, 2018 | 11:10 PM
turbo_outlaw's Avatar
Default Hd2 kit plus dual feed mod ok?
I have already done the hd2 kit to my 4l80e. Is it ok to also do the dual feed direct clutch mod at the same time?
Old Apr 8, 2018 | 06:29 AM
GMCSIERRA5.3's Avatar
You will need too take out the hd2 sandwitched seperator plate and use a oem or regular transgo plate
Old Apr 8, 2018 | 10:25 AM
Thank you. Do I still drill the stock plate for shift firmness?
Old Apr 8, 2018 | 12:56 PM
Yes..are you doing a rebuild on it? To do the dual feed you need the transmission apart to take out the direct drum seal
Old Apr 8, 2018 | 05:38 PM
Yes, I took it completely apart for inspection. I drilled the hole, removed the center seal, removed the second sealing ring and blocked off the reverse lube hole.
Pretty much right after I did all this I read something about this mod plus the full hd2 kit wouldn't work. I'm a little worried now, but as mentioned I think I can just switch back to a regular separator plate and be safe.
I might need to plug where I drilled for the hd2 pressure relief valve..??
Hopefully where I drilled the hole in the valve body between the torque signal and "void" passages it won't hurt anything..??
Old Apr 8, 2018 | 06:00 PM
BlackGMC's Avatar
Resident Retard
I believe you should not do step 4 & 5 on the HD2 kit if you are going todo the dual feed mod. That is what i did i believe.
Old Apr 8, 2018 | 06:18 PM
Yes I believe I'll have to undo steps 1, 4 and 5.
Old Apr 8, 2018 | 06:20 PM
305juan
Jun 30, 2012 09:03 AM
Tootall
Mar 26, 2011 09:49 PM
SuperchargedSS
Jun 13, 2009 12:13 AM
thunder550
18
May 19, 2008 08:33 PM
