Hate my 3.42s when towing, suggestions?
Old Dec 31, 2005 | 01:18 PM
shadowamker's Avatar
Default Hate my 3.42s when towing, suggestions?
I tow either a 12' or 16' open trailer, pulling 3 or 4 atvs, depending on who goes. The place I go has alot of mountains and the tranny is continously going in and out of gear. Even in the tow mode this happens. I m scared I m going to tear out the tranny or blow up the truck. I know going to 3.73s or even 4.10s would solve the problem but I cant afford to do this at the time. I actually thought with the "towing package" it would ve came with 3.73s, had I known it didnt I probably would ve looked at a different truck. But that s my own fault for not asking or checking first. No way I can trade the truck either, I would take a beating on it, especially with all the red tag sales etc etc.
I would like to get a computer re-programmed but again, I dont have $500 to get one.
I did install a flowmaster muffler. Could this have caused me to lose some performance in the low to middle range? Would installing a K&N filter help any? What about the vette servo? Or am I pretty much screwed and going to have to deal with this until I can save the money to either do the gears or computer?
I m going on a 1000 miles trip in March pulling the 16' trailer so I need to do something before we leave if possible.
BTW I have an 05 crew cab, z71 with the 5.3 and 3.42 gears. No mods other than the flow master.
Brad
Old Dec 31, 2005 | 01:40 PM
treyZ28's Avatar
dude, you just need more gear. the 5.3 is going to be way out of its powerband on the highway.
with 3.42s and 265/70/17 is at 1600rpm at 65mph. that is just NOT going to cut it on a gas engine unless its the 8.1 or something. I doubt my 6.0 would like being at 1600rpm on big hills and a trailer.
Old Dec 31, 2005 | 01:43 PM
1FUNZ71's Avatar
14 Second Truck Club
I feel your pain. I have a custom tune, but it doesnt help as far as towing goes. I didnt have it set up for towing. I just leave it in Drive and take the 11-13 MPG when I tow. I will be going to 4.10's when the cash is available. That is towing a 12ft trailer that wieghs about 1500lbs with about 1000lbs on it.
Old Dec 31, 2005 | 02:02 PM
TXsilverado's Avatar
390's or 410's will make you happy. hell 373 mighte even do the trick without losing any milage in comparison to the 342's.
Old Dec 31, 2005 | 05:58 PM
smooth sierra's Avatar
save up and buy some 3.73's they will be more than enough for what you are towing and I will bet you see no effect on your mileage when not towing
Old Dec 31, 2005 | 08:31 PM
When towing your trailer always have the tranny in 3 not D (don't allow the tranny to shift in over drive) because your OD can not handle the constant shifting in and out of gear. A 4L80E will not solve your because the weak part of the 80E is the OD, I have replaced several 80E's in my dad's diesel because he always has it in OD when towing a 30 ft. flat bed trailer.
Old Dec 31, 2005 | 09:16 PM
duwem's Avatar
Gears arent that expensive, just find someone with a dial indicator gauge that has doen it before to help you and it wont be bad at all.
Old Dec 31, 2005 | 09:42 PM
BadAssChevy327's Avatar
i got 3.73s and i towed 6,000+ pounds from miami to ocala , bout 300 miles , in towhual mode in d . with the a/c on doing bout 80 most the way in overdirve crusiin . coming out of tolls no problem , truck had awesome power for the weight it had on it . and i think ia vewraged 13 mpg i dont remember or 12
Old Dec 31, 2005 | 09:52 PM
If I m going up hills I ll pull in 3 in tow mode. If its flat and no hills, I ll put it in D still in tow mode. But even in 3 tow mode, some of the hills, it ll drop down one more gear, rpms real high, lose speed, and just feel like its straining. I just dont understand GM putting a tow package on a truck and using such a terrible gear.
As far as price on the gears, wouldnt it cost roughly $800-$1000 to have it done right? I figure $400 for the gears themselves.
Guess when I go on the trip I ll just have to baby the truck on the hills like I m doing now. But we re heading to Texas so I m hoping it ll be mostly flat.
Brad
Old Dec 31, 2005 | 10:06 PM
LVSTOGOFST2002's Avatar
gears themselves can be had for cheap. lots of used ones around for maybe 100 bucks, brand new are between 150 for cheaper yukons, ( still good quality, available through randy's ring and pinion ) and oem quality aam ( otherwise known as original equipment gm gears ) for 200. i have gm 4.10's in mine, and have zero gear noise, and they work awsome. worth the extra. the install can be done yourself honestly if you can get ahold of a dial indicator. don't be scared. This site convinced me to do mine, and i'd never have anyone do a rear end for me again. gm gears, with oem shims=good gear pattern, zero whine. made life real easy on me. dont be scared.... we'll walk you through it if need be.
