Harsh 1-2 shift on light throttle
Old Nov 10, 2009 | 08:28 PM
scooter k's Avatar
Default Harsh 1-2 shift on light throttle
I have a RPM trans and my 1-2 shift is extremely hard on very light throttle applications. My tuner has decrease shift pressures and even added TM but doesn't seem to help. Shift is fine at WOT just at very light throttle applications is when it does it. What do I need to do
Old Nov 10, 2009 | 09:01 PM
viciousknid's Avatar
Where's the Beef?
Mine is Much lower than stock Trying to find the thread where I posted the pressures
Old Nov 10, 2009 | 09:02 PM
BlackGMC's Avatar
Resident Retard
Your on the stock Torque converter right?
Old Nov 10, 2009 | 09:07 PM
Where's the Beef?
You thinking it's staying locked during shifts?
Did he increase the shift times any?
Old Nov 10, 2009 | 09:12 PM
BlackGMC's Avatar
Resident Retard
naw nothing like that... When i installed my shift kit and still had the stock TC, it had teh worst 1->2 shift at low throttle....
Old Nov 10, 2009 | 09:28 PM
scooter k's Avatar
I'm on a 2600-2800 stall
Old Nov 10, 2009 | 09:30 PM
scooter k's Avatar
I wondered if it has something to do with the TVS and MAF?? Right now when it shifts if you are standing outside watching you can see the shock go to the rearend as you see it shift. I'm anticipating shift and letting off right now.
Old Nov 10, 2009 | 09:34 PM
Where's the Beef?
there is a similar thread like this some where from a couple months ago. I'm at work so cant do much searching to find it.
I know I posted my pressures in it but he ended up finding a different solution.
Old Nov 10, 2009 | 09:41 PM
scooter k's Avatar
https://www.performancetrucks.net/fo...hift+pressures
This one maybe??
I'm using HPT
Old Nov 10, 2009 | 09:53 PM
trever1t's Avatar
2nd fastest 5.3 ECSB
common issues with the 4L60e and shift kit. I run lower than stock pressures in the lower area of the tables for the 1-2 and it's still a good bump at low throttle.
