for the hardcore guys, Panard bar, Torque arm setup
Old May 29, 2007 | 09:58 AM
Quik's Avatar
5 year bitches!
Default for the hardcore guys, Panard bar, Torque arm setup
what are some thoughts of a panard bar, torque arm rear suspenson setup? figure they work well given what they are and possibly could be built and not having to relocated the fuel tank and still be able to keep the sprigns and shocks currently used. brackets can be found on a TB or a suburban
Old May 29, 2007 | 10:05 AM
Bill Reid's Avatar
Subscribing
Bill
Old May 29, 2007 | 01:47 PM
kbracing96's Avatar
Leafs are pretty good with side to side which is what a panhard bar would support. But twisting, or axle wrap causing wheel hop is more what they suffer from, so you could defiantly benefit from a torque arm.
Old May 29, 2007 | 05:56 PM
405hpta's Avatar
Banned
you wouldn't run a torque arm/phb setup with a leaf spring, you would need to switch to a coil spring in the rear. A torque arm setup wouldn't be the best option for a truck, 4 Link would be more worth while.
Old May 29, 2007 | 09:28 PM
Quik's Avatar
5 year bitches!
again 4link involves removing the tank and replacing with fuel cell. which i cant do at the moment
as for this idea, its cause my DJM hangers dont allow Caltracs which i can probably do a Torque arm, panard bar setup for alot less then caltracs and new hangers
Old May 31, 2007 | 01:00 AM
8MC's Avatar
8MC
We run a panhard bar & torque arm with leaf springs on our '66 Mustang road-race car. With about 600 hp to the tires on a leaf spring setup, it needs all the help it can get. While the leaf springs are stiff, the panhard bar just helps insure no side-to-side, but the torque arm is a must for wheel hop on hard acceleration
Old May 31, 2007 | 08:44 AM
Quik's Avatar
5 year bitches!
haveany pics of it on the mustang?
Old May 31, 2007 | 03:28 PM
BlackGMC's Avatar
Resident Retard
Maybe these will help, here are a couple of examples of 3-Links from lateral dynamics, mainly for road racing not sure if it is good for drag racing.
Additional Info
Differences between a Panhard and a Watts 3-lnk
I hope that helps.
Old May 31, 2007 | 03:43 PM
nightrunner's Avatar
Mr. Obvious
are you sure you need to relocate the gas tank?
Sport Side has a 4link and i dont think he has relocated his tank
Old May 31, 2007 | 11:18 PM
8MC's Avatar
8MC
Originally Posted by Quik
have any pics of it on the mustang?
I don't think I have any pics of just the panhard bar or torque arm. I can get some as soon as the new rearend is back from being narrowed & adding 1.5 degrees negative camber
