half shafts
Old Apr 12, 2009 | 05:03 PM
5.3serria03's Avatar
Default half shafts
anyone have these crap out on them? if so any tips on swapping them out. thanks in advance
Old Apr 15, 2009 | 04:06 PM
also anyone know of a good place to get them? dealer wants 531 and change a piece.
Old Apr 15, 2009 | 07:57 PM
1989k1500's Avatar
Advance Auto parts, Auto Zone, etc.
Its pretty straight forward to swap them. The 6 bolts on the diff, one big nut on the outside end of the cv behind the little dust cover in the center of the rotor. IIRC you might have to unbolt the shock from the lower mount.
Old Apr 20, 2009 | 08:17 PM
turboescalade's Avatar
its really easy to swap them out.. i have had them blow out of my caddy a few times man, i have looked into this for a long time, if you plan on makin lots of hp. look at gettin some custom ones made.. otherwise like the man above me says, check out those places, they will prolly give you a core charge for yours too
Old Apr 25, 2009 | 05:20 PM
Default this blows
thanks for the replies. but i got my front end apart today only to find out that the wheel bearings are bad. do these get pressed out or do you replace the hub and bearing as an assembly? it looks like it unbolts from the knuckle with three bolts.
Old Apr 25, 2009 | 09:59 PM
budhayes3's Avatar
PT's Slowest Truck
The hub and bearing comes as an assembly as far as I know...
Old Apr 25, 2009 | 10:28 PM
53bowtie's Avatar
yes, the hub is all one unit with the bearings built in and the abs plug in coming out of it. Just has 3 bolts holding it in from the back.
SloSVO
Nov 22, 2020 07:34 PM
BROKE-aSS-BLAZER
Oct 13, 2017 03:50 PM
StrokeTheLS
Sep 29, 2015 08:33 PM
Jake99
Sep 16, 2015 10:14 AM
mayko
Sep 7, 2015 12:24 PM
