half shafts
Advance Auto parts, Auto Zone, etc.
Its pretty straight forward to swap them. The 6 bolts on the diff, one big nut on the outside end of the cv behind the little dust cover in the center of the rotor. IIRC you might have to unbolt the shock from the lower mount.
its really easy to swap them out.. i have had them blow out of my caddy a few times man, i have looked into this for a long time, if you plan on makin lots of hp. look at gettin some custom ones made.. otherwise like the man above me says, check out those places, they will prolly give you a core charge for yours too
thanks for the replies. but i got my front end apart today only to find out that the wheel bearings are bad. do these get pressed out or do you replace the hub and bearing as an assembly? it looks like it unbolts from the knuckle with three bolts.
The hub and bearing comes as an assembly as far as I know...
BROKE-aSS-BLAZER
Oct 13, 2017 03:50 PM
StrokeTheLS
Sep 29, 2015 08:33 PM
