guys who have built traction bars need your help!
sorry for the delay, been busy looking for a new job so i can get the heck away from directv and been tryin to get my other truck fixed to use as a daily. anyways heres the front brackets, gota take the rear and bars to do the coatin on sometime this weekend hopefully if i get time
Sry few days late on finding this but i have made my own before with absolute scrap from steel yard using nuts welded on pipe for thread adjustment and a piece of triangular plate with holes drill in them and worked pretty good for what i had in it..
but since then i have become a supervisor in a machine shop so i have alot more capabilities on building stuff n wanted to share my latest set on my wifes truck with you guys ...
The only thing i dont like about them is i didnt make the aluminumn bushing, just use good ole grinder n grinded down the ears on the factory bushing in the leaf. lithiem grease takes care of the squeeks most of the time..
Praise The Lowered
Praise The Lowered
The real term is high misalignent spacers.. They slide in on either side of the heim hole allowing the use of a smaller diameter bolt and the hiem gets more rotation before hitting the spacer..Just a better way of doing it
http://www.polyperformance.com/shop/...cers-p-19.html
i like the bracket made for the eye of the leaf .
why not just use a new shock mount instead of the relocator? could also get them more perpendicular if you were to do this.
11 Second Hall Moniter
Okay, that makes sense. I hadn't heard that term before.
