got a 02 lq4
Old Feb 11, 2011 | 01:15 PM
chevyl33's Avatar
Default got a 02 lq4
just picked up a 01-02 lq4 an was wounding if you bolts up to a 05 4l60e like is the crank goin to be to long
Old Feb 11, 2011 | 04:07 PM
1Bear's Avatar
If it truly is indeed a 01-02 LQ4 (would have aluminum heads, not iron), then yes it will bolt up just fine to your 4L60E using your existing flexplate.
The earlier 99-00 iron headed models are the ones that were also equipped with the longer crankshafts.
Old Feb 11, 2011 | 05:24 PM
chevyl33's Avatar
the back of the crank sticks out about a half inch or so im guessing its older then 01-02 then an if the crank is longer how can you make it work with the 4l60e
calsdad
Jun 14, 2023 11:07 PM
02AWDAWSDenali
Oct 1, 2015 05:08 PM
lxcoupe
Sep 29, 2015 09:20 PM
Slammed silverado
Sep 28, 2015 06:14 PM
zraffz
Sep 8, 2015 07:40 PM
