A good TH400 TC
Old 02-01-2012, 01:13 PM
stokedc10's Avatar
Default A good TH400 TC
I am in need of a good th400 torque converter is that not going to blow up on me. I bought my first one off ebay for 150, and i got what i paid for it was a 22-2800 stall that actually stalled at 4800.. and still slipped. The second one I actually got with the transmission when i bought the truck with no motor. it was a 3600 nitrous stall that stalled at 3200 on a foot break. I really liked that converter and i have no idea who made it but I screwed it up when i did a burn out on a cold tranny.
MY issue is when I lay into it and slap second or third it doesnt shift right away, Its like it goes into neutral. and I am really hoping that its the converter and not the tranny.
It was built for 1000 HP and has a manual valve body. My motor makes 462 at the crank and 465 FT. Lbs.
I am trying to keep it as cheap as possible but I want something that is going to hold up.
Any suggestions?
Old 02-01-2012, 02:47 PM
Gingervitis Addict
slow67's Avatar
That's definitely a transmission issue. First thing is to check and make sure that the linkage is EXACTLY correct on the transmission (the cable should be able to freely go into/out of the linkage on the trans in each gear). If thats not it, the trans has to come out.
Old 02-01-2012, 04:44 PM
stokedc10's Avatar
The linkage is fine. Its a B&M slap shifter, and all the linkage works properly on the outside of the transmission. I can lay into it, shift it and it acts like it goes to neutral, then if i let out it will shift. I pulled the motor and trans already, i had some other things with the motor i wanted to address, so everything is already out.
Old 02-02-2012, 07:01 PM
Vince B's Avatar
I would have to agree that it sounds like a trans issue. As for a converter if you buy a cheap one that is what you get. A good converter will cost over $800.
Old 02-02-2012, 07:19 PM
FormerVendor
Jake's Performance's Avatar
Not for a TH400 Vince...
A nice TH400 billet cover converter shouldn't cost more than $600 IMO, and the billet cover isn't even necessary on many combos because of the lack of lockup.
Old 02-04-2012, 09:44 PM
stokedc10's Avatar
Yeah, I suppose I will take it to a transmission shop and have them look at it, i just hope its nothing major
Old 02-04-2012, 10:13 PM
GREENSIERRA's Avatar
I have had good luck with ATI and Coan converters behind high hp big blocks with TH400s
it sounds like a tranny issue to me
DrX
08-19-2015 04:45 PM
Blackrat48
08-16-2015 11:56 AM
Sierra1320
08-15-2015 08:04 PM
ALynch
07-06-2015 09:49 AM
Quick Reply: A good TH400 TC
