Is this a good lowering kit?
Old Dec 11, 2008 | 09:45 PM
BlackGMC's Avatar
Resident Retard
Default Is this a good lowering kit?
I am considering this lowering kit and shocks, the price seems really good, just wanting to know want everyone else thought?
http://www.stylintrucks.com/part.aspx?partid=23545
Old Dec 11, 2008 | 09:49 PM
Mangled03gmc's Avatar
Baltimore Whore
I do believe that is the same kit I have on my truck.. So far so good.. A lil stiff but what kit isn't
John
Stoichiometric's Avatar
I had that kit on my truck. I changed the front springs back to stock and used a 2(1/2?) control arm. I am able to use stock length shocks in the front now which is nice. I actually would like to have my whole truck back to stock ride height.
Old Dec 11, 2008 | 09:59 PM
BlackGMC's Avatar
Resident Retard
So it did not ride good? All the posts I could find said the beltech street performance shocks were really good...
Old Dec 11, 2008 | 10:02 PM
I didn't like mine.
Old Dec 11, 2008 | 10:03 PM
BlackGMC's Avatar
Resident Retard
What did you not like about them? I want a soft ride, no harshness or stiffness..
Old Dec 11, 2008 | 10:05 PM
Baltimore Whore
Well that is hard to say then, I havn't heard of any lowering kit that gives a soft ride.. I def can say I don't have a soft ride from mine...
John
Old Dec 11, 2008 | 10:06 PM
BlackGMC's Avatar
Resident Retard
Well mine can't get any worse, mine rides like a covered wagon now....
Old Dec 11, 2008 | 10:14 PM
I had them in the front only. The compression was OK, they would blow through on big impacts and let the front end bottom. They had almost no rebound. One shock started leaking about 1 month after installing. I replaced them with Bilstien HDs, those have been working flawless. I am very happy so far. The Bilstiens ride very comfortable, no harshness at all.
I am still looking for something to fit the rear. My truck is ~5" drop in the rear so the 4" drop shocks are too long and the 6" are too short. I have a set of 6" drop explorer no name shocks in the back that I had to weld extensions on(don't ask) to allow for a normal amount of droop.
Old Dec 11, 2008 | 10:16 PM
It is very important to get the bumpstop to stop the suspension right as your tires buzz the fender liners. You need to make use of as much wheel travel as possible once you are lowered, especially if the only shocks that fit don't work.
