good drop for z71?
Old Oct 28, 2005 | 12:58 AM
Default good drop for z71?
thinkin about dropping my z71 and getting some centerline 17's and building a 6.0 up(building it up wont happen for a year..and would take 2 yrs to complete...cuz money isn't there lol).
would a flipkit and 2" drop shackle in the back be ok? or to low. i plan on ladder bars and panhard bar, swaybar setup. or just take it all out and 4link/coilover
the front...i have no idea. i know loosening the torsion bars can get me low but not much...and it wont handle that great.
wuts out there for us 4wd guys to lower the front for performance. not really for just looks.
Old Oct 28, 2005 | 01:21 AM
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
The front you can do spindles from McGaugheys and they also make torsion bar keys to dorp the truck. On the back take the lift blocks out and use 2wd u-bolts and then spindles.
Old Oct 28, 2005 | 03:40 AM
spindles...do u mean shackles for the rear?
i was thinking either remove the 2" block and get 2" drop shackles...but im a minitrucker at heart and like it as low as i can. but i cant get my truck notched...so i think the block/shackle will be what i do.
for the front they make lowered spindles for the 1500? link to any of em?
Old Oct 28, 2005 | 08:04 AM
white1's Avatar
After hunting season I plan to pull th blocks and add some 2" shackles in the rear, and loosening the torsion bars in the front. I saw somewhere the lowering spindles for 4wd's but I dont remember who makes them.
Old Oct 28, 2005 | 01:49 PM
NBred94's Avatar
Your options are a bit different starting with the Z71, but have you checked out this guy's truck:
http://www.x1nova.com/K1500.html
It looks seriously cool, maybe it could give you some ideas.
(I copied and pasted this from another thread, so no, you're not allucinating)
Old Oct 28, 2005 | 03:02 PM
white1's Avatar
What does all....al.That big word mean?
Thats the same truck in GM high tech performance isn't it?
Old Oct 28, 2005 | 03:22 PM
i think he meant 'hallucinating' lol...
i have read that article and seen the link before.
but i dont want to just loosen my t-bars...is there any other way to get a stiffer ride up front? i had loosened t-bars on my 2wd mazda and it rode like ***. but the frame was laying on the bumpstops...lol
Old Oct 31, 2005 | 01:03 PM
NBred94's Avatar
Yep, dropped the "h" on the earlier post.
Old Oct 31, 2005 | 04:22 PM
Mort's Avatar
Cool
If you drop the front more than 3" it will kill your CVJs. It is probably not the best for them at 3" either. McGaughys has a 2"/4" drop. You might be able to get 3" up front using spindles and lowering your torsion bars or by putting in lowering keys. Not much else you can do up front. Maybe a good set of shocks and a bigger swaybar will firm it up a little for you. Their hanger/shackle compination is adjustable and you should be able to get 5" with it. At least I got that out of their kit for my 1500HD. Check them out they make good stuff. So you can get 2"/4" and maybe 3"/5" if you are inventive. You will need 17" wheels up front to run their better spindles and 18" would be better because the spindles will still need to be trimmed a little to fit the 17" wheels AFAIK.
Old Oct 31, 2005 | 04:43 PM
1slow01Z71's Avatar
Yeah I meant shackles out back and McGaughy's(sp?) makes the spindles that I was talking about.
mzoomora
Jan 3, 2016 07:06 AM
V-seriesTech
Jul 28, 2015 12:28 PM
LoneSStar
Jul 27, 2015 09:27 PM
mrgrim
Jul 8, 2015 08:12 AM
