Going 4L80E - stay AWD or go 4WD?
Old Jan 23, 2009 | 05:54 PM
brent1976's Avatar
11 Second Club
Isn't the front diff what makes the 4x4 jerky in the turns? I figured with 4x4 with the awd front diff it wouldn't be rough feeling on the corners, or am I thinking wrong.
Old Jan 23, 2009 | 09:39 PM
Rick_Vor's Avatar
Originally Posted by Justin @ EAD Performance
I wouldn't do the 27 spline output shaft in the 4L80e. There have been numerous failures. Get a 32 Spline Input Gear for the NVG149.
Thanks for the feedback Justin. I couldn't find it on your site. I'll give you guys a call on Monday.
Thanks, Rick
Old Jan 24, 2009 | 10:00 AM
Justin @ EAD Performance's Avatar
Thanks, Rick
Rick,
Sounds good, looking forward to hearing from you.
Thanks
Justin
Old Jan 24, 2009 | 08:15 PM
Bo185's Avatar
Actually its the transfer case that cases the jerking on pavement. If you locked in 4hi with a standard transfer case a chain or gears locks the two dive shafts together.
The front wheels, in a turn, move (faster) than the rear and that puts strain in the driveline. Because the two divelines are turning at the same speed while locked in 4hi, but the front wheels want to turn more cause stress on everything!
Basically its the same principle as a rear end in a turn.
The AWD cases have clutches in them that slip a little while the truck turns. The clutches give just like a limited slip in a rear end and reduce the stress in a turn.
Off road when turning and locked in 4x4 the tires give enough to in over stress the driveline.
I wouldn't drive in 4hi without the two speed autotrac transfer case or the AWD transfer case on pavement. Although you can lunch in a straight line in 4hi.
Old Jan 25, 2009 | 10:26 AM
brent1976's Avatar
11 Second Club
I learned my new thing for the day.
Old Feb 15, 2009 | 12:22 PM
BaddillaK's Avatar
in the rain mine stays in auto unless i want to slide, and i havent had a problem, but i dont have near the power of you guys
blownss27
Aug 14, 2020 08:27 AM
Brandonlflr12
Sep 9, 2015 03:54 PM
MA$TER_E
Sep 9, 2015 03:14 PM
askkmb
Sep 7, 2015 10:58 PM
muncie21
Sep 7, 2015 09:55 PM
