View Poll Results: What combo?
3.73s + 3000 stall
31.58%
4.10s + stock stall
0%
4.10s + 3000 stall
68.42%
Voters: 19. You may not vote on this poll
Gear/stall combo
Old Apr 25, 2008 | 02:07 PM
00ChevyScott's Avatar
Wearin' da big hat
Default Gear/stall combo
what should i do.
Street/Strip truck. It is also my DD.
I want to be able to mess around more on the street than just having a fast ET. Like better get up and go, easier accelleration, and somewhat good highway punches. This truck is too heavy, and the 3.42s arent cutting it
Old Apr 25, 2008 | 02:08 PM
Stoichiometric's Avatar
Is this your DD, what cam, any power adders planned?
Old Apr 25, 2008 | 02:11 PM
Wearin' da big hat
Edited first post while you replied with that info.
For now, stock cam, but if i ever save up enough to change it, itd be a 212/218 112 comp cam
No FI or nitrous.
Old Apr 25, 2008 | 02:18 PM
BlackGMC's Avatar
Resident Retard
what tire size?
Old Apr 25, 2008 | 02:22 PM
Wearin' da big hat
30.5 right now. 265/70/R16
but, im probly about to buy titan 18s and run say a 275/55/R18
So im not sure, but most likely around a 30 inch tire, maybe 29
Old Apr 25, 2008 | 02:23 PM
Do you already have 3.73 gears?
Old Apr 25, 2008 | 02:26 PM
Wearin' da big hat
no. I have 3.42s
Old Apr 25, 2008 | 02:47 PM
4.10s and the 3k stall will obviously shine at the track, but you will sacrifice some mpg to get that. If you do a lot of HWY then 3.73 and 3K stall would be a pretty good compromise to get decent mpg on cruise when the converter is locked up. 4.10 and stock converter will probably get you the best around town mpg, but less on the HWY and probably not launch as hard as the 3.73 and 3k stall. Tough choice!
Old Apr 25, 2008 | 02:52 PM
sickREDsierra's Avatar
just FYI, i only lost 0.4 mpg when i went from 3.23 to 4.11
the stall makes a huge difference getting it moving, and the gears/shift points make the rest. my truck is night and day difference between stock and now.
Old Apr 26, 2008 | 12:44 AM
Wearin' da big hat
That is problem im having. Would it be better to keep a longer gear ratio and make up for it with a stall?
anyone know the MPH differences between 3.73s and 4.10s?
