gear ratios
Old Sep 28, 2005 | 07:50 AM
Southernstyle95's Avatar
Default gear ratios
what gear ratio should i run with 46" claws. And whats the lowest gear ratio i can fit into a 10 bolt
Old Sep 28, 2005 | 09:27 AM
StrokerAce03's Avatar
I wouldn't recommend running a 10-bolt with that big of a tire. A 14-bolt would be much better suited for something that large. As far as ratios go, you're probably gonna need 5.13's or maybe lower if they make them any lower than that.
Old Sep 28, 2005 | 02:15 PM
Default dana44
would a dana 44 be alright for 46" tires
Old Sep 28, 2005 | 02:31 PM
14 Second Truck Club
A 44 is about even with a 10 bolt, comparable ring gear and spline sizes.
Old Sep 28, 2005 | 04:33 PM
You're gonna need 1-ton running gear to handle them.
Old Sep 29, 2005 | 11:17 AM
redneck01z71's Avatar
would not even think of running 46's on a 10 bolt. And if you are going to run these on a 1 ton (dana 60 or 14 bolt), what you are going to do then? Heavy mudding, cruising, rock crawling? In extreme applications, a 2 1/2 ton rockwell may be needed
Idryfly5
Sep 2, 2022 08:55 PM
thunder550
Oct 8, 2015 04:53 PM
Noah Burns
Oct 5, 2015 06:46 AM
Bluecollar Hotrods
Sep 1, 2015 07:45 AM
1979rs/z28
Aug 24, 2015 08:43 AM
