gear indication
Old Jun 6, 2016 | 10:05 PM
89sierra's Avatar
Default gear indication
hey guys don't know if this is the right spot to post this. or if I am crazy for thinking it.
the truck is an obs half ton with a column shift. that has a custom gage cluster in.
where my problem is now that I did the custom cluster. I lost the gear indicator in the cluster that was just a cable attached to the column.
is there anyway to wire in a gear indicator light from the transmission or computer?
counting clicks and trying to remember what gear I am in just seems counter productive.
thanks
drew
Old Jun 7, 2016 | 12:15 AM
someotherguy's Avatar
Dakota Digital should have a sender you can use for that. Or maybe you could use a 1995-up range switch and swap out the shifter linkage stud for the 1995-up one to accommodate it (it's longer) ?
Richard
Old Jun 8, 2016 | 09:29 PM
89sierra's Avatar
thanks they don't look to bad lookar has a nice set up too
do anyone know how the factory gear indicator on the 99 and up truck works
Old Jun 8, 2016 | 10:54 PM
DrX's Avatar
DrX
Range switch:
Attached Thumbnails gear indication-range-switch.jpg   gear indication-range-switch-2.jpg
Old Jun 9, 2016 | 09:01 PM
89sierra's Avatar
hey thanks for that really helps. now I just need to figure out a way to get it to work together.
Old Jun 9, 2016 | 09:25 PM
DrX's Avatar
DrX
Think I am going to put a 1" OLED in my dash beside the Holley digital dash for a shifter position indicator. Will wire the range switch to a small circuit board that controls the OLED.
Old Jun 9, 2016 | 09:58 PM
89sierra's Avatar
I was going to run a couple different leds as that what I have set up for the other lights. its just like you said finding a circuit board or something for the different inputs to outputs to control them
Old Jun 9, 2016 | 10:18 PM
DrX's Avatar
DrX
I will just build one.
Old Jun 10, 2016 | 02:39 PM
DrX's Avatar
DrX
I added some clarification of the circuit functions
Old Jun 13, 2016 | 03:09 PM
89sierra's Avatar
if you want to build 2 let me know as that's probably a little above my pay grade lol.
