Fuddle Converter discussion.
Old May 20, 2006 | 09:13 PM
FarmerBeau's Avatar
Sexy Party Mod
Default Fuddle Converter discussion.
Im looking into getting a fuddle converter. I dont tow. They say that basically all that is different between the "Performance truck series" and the "HP Truck series" is the ability to tow. As i have gathered, is the ability to tow is based on the clutches and methinks there is a different clutch in the HP truck series. I want to know, Will there be a difference in times based on the which series i choose. I want to spend as little as possible, same as anybody but then again i want to put out the best times possible. I have called fuddle but i guess they are busy. Anybody have any know-how on this subject. Thanks for reading and suggestions and comments are welcome.
Q: Which fuddle converter will put out the best times?
Old May 21, 2006 | 01:26 AM
i have the performance series because i will not be towing. yes the HP has a different clutch, a larger one. i am very happy with my 400$ perf. stall rated at 3200 even with the extended cab still stalls to about 3400 but they come loose anwyays. john at fuddle said the performance would hold a trucks weight as long as we didnt try to tow anything with it or have really heavy payloads
Old May 21, 2006 | 08:40 AM
FarmerBeau's Avatar
Sexy Party Mod
cool! But will the clutch make a difference in the ratio or the performance? I talked to john earlier in May and he was saying that i needed a HP serie. I was like because i never tow. I know abselutely nothing about how a converter works.
Old May 21, 2006 | 10:24 AM
i dunno, but he told me if i didnt tow i could use the performance and im extended cab....maybe when you are starting to make a whole lot more power like a turbo set up then you would want to have a HP series but the performance should do...on the website the only difference is the fact that the HP series has a "highly towable clutch"
Old May 21, 2006 | 04:02 PM
FarmerBeau's Avatar
Sexy Party Mod
Im really thinking that i dont need a hp series. Im gonna need a verter pretty quick though.
Old May 21, 2006 | 04:10 PM
white1's Avatar
You dont need the HP Beau (you dont make enough power ) JK. If I remember correctly you really dont need the HP unless you tow. As far as that changing your ET any (I know you need all the help you can get ) I dont see where that would really make a difference. Just get the cheaper one, youll be fine
Old May 21, 2006 | 09:37 PM
good advice white, i took that route and am still happy, now i jsut gotta get the truck back from the shop with a blown carrier bearing
Old May 26, 2006 | 08:03 PM
I have heard of Fuddle only recently. How dependable are they? Are they better than a Yank or Vig.? Why?
Old May 26, 2006 | 08:07 PM
i understand they are just as reliable but with a far better upgrade, repair, exchange program
Old May 26, 2006 | 09:28 PM
PM SSlow 4.8, he's ordering his 3500 Fuddle this weekend.
jscherbs
Mar 24, 2017 07:20 PM
Go5.3tt06
25
Sep 4, 2016 10:25 AM
TAPyvehc93
Jan 8, 2016 10:47 AM
jtphelps289
Sep 11, 2015 06:37 PM
06 4.8
Sep 11, 2015 10:36 AM
