frt drive shaft & transfer case issue
Old Jun 1, 2005 | 07:39 PM
w41quad4's Avatar
Default frt drive shaft & transfer case issue
Recently I started to notice a noise coming from under the truck in the transfer case area. Af first I thought the noise was from the rear driveshaft, so I bitched when I bought the truck and they replaced the rear u-joints & slip-yoke putting in the newer style nickel plated one. This cured some of the issues for a while, then a similar noise returned. This time I'm pretty sure its from the front yoke on the transfer case, if i grab the front drive shaft I can move it up and down & side to side pretty easy, now I know it should have some play but this is enough play that I can mimick the same noise. So has anyone had this issue before? Just wondering if this is something that is common?
Thanks
J
Old Jun 2, 2005 | 02:32 PM
dewmanshu's Avatar
Moderately Differentiated
No...shouldn't move like that at all. Take it back. Nothing should be easily moved any where between motor and wheels.
thunder550
Oct 8, 2015 04:53 PM
MileHighSierra
Jul 22, 2015 11:19 PM
04BlackGmc
Jul 16, 2015 04:10 PM
alex226
Jul 16, 2015 10:55 AM
Gadgetized
Jul 7, 2015 04:40 PM
