Front Suuspension Noise
Old Aug 29, 2007 | 02:21 PM
04extcab's Avatar
Default Front Suspension Noise
I'm trying to chase down a "rattle" noise when I hit bumps in the road in my right side front suspension and want to know if anybody knows of a TSB related to the control arm / front crossmember area of our trucks (2WD)? I found where ridered4life posted a message saying there was a TSB fix for this but details where a little sketchy...something about a slot in the crossmember where the control arm attaches ,installing some washers, antiseize, and retorqueing to 100 ft.lbs. but I need a little more to go on before I start tearing into the front suspension. This isn't the intermediate steering shaft issue; I've already fixed that defect. This noise is driving me crazy.....Oh, I had the front end checked at an alignment shop and they said nothing "appeared" to be loose....but I know what I'm hearing.....
Old Aug 31, 2007 | 08:21 AM
04extcab's Avatar
Alright, I found an answer. Hopefully this will help others with a similar problem....
Snap/Popping Type Noise Coming from Front of Vehicle (Remove Bolt-In Front Crossmember and Add Washers) #03-08-61-002G - (Feb 14, 2006)
2003-2006 Cadillac Escalade
2003-2006 Chevrolet Avalanche, Suburban, Tahoe
2004-2006 Chevrolet Silverado
2003-2006 GMC Yukon, Yukon XL
2004-2006 GMC Sierra
1500 Series (½ Ton) and 2500 Series (¾ Ton) with Two-Wheel Drive
This bulletin only applies to 1500 and 2500 series 2WD vehicles with recirculating ball type steering.
This bulletin is being revised to add the 2006 model year, update the correction information and change the quantity of parts needed. Please discard Corporate Bulletin Number 03-08-61-002F (Section 08 -- Body and Accessories).
Condition
Some customers may comment on a snap or popping-type noise coming from the front of the vehicle. This condition is most apparent during hard left or right turns at low speeds. Going over bumps while turning may also aid in producing this noise.
Correction
Remove the bolt-in front crossmember and add washers using the procedure listed below.
Important: DO NOT slot the mounting holes on the crossmember as stated in previous bulletins. Slotting the holes has been found to be less effective and, in some cases, causes the noise condition to be more prevalent.
1. Raise and support the vehicle. Refer to Lifting and Jacking the Vehicle in the General Information sub-section of the Service Manual.
2. Remove the mounting nuts, bolts and the front crossmember from the vehicle.
3. Clean all the undercoating off the crossmember in the area of the mounting holes.
4. Reinstall the crossmember with the bolts and nuts. On the driver and passenger side, add washer P/N 11509592, or equivalent hardened washer (see dimensions below), at each bolt head and nut location.
Tighten
Tighten the bolts to 120 N·m (89 lb ft).
5. Apply an even coat of Anti-Corrosion Coating, P/N 12346501, or equivalent, to the crossmember where removed. Overlap the original coating in order to provide an effective corrosion protection.
Inside Diameter Outside Diameter Thickness
14 mm (0.551 in) 35 mm (1.38 in) 3 mm (0.118 in)
Parts Information
Part Number Description Qty
11509592 Washer 8
Warranty Information
For vehicles repaired under warranty, use:
Labor Operation Description Labor Time
E1730 Crossmember, Front Suspension - Replace Use published labor time
black03rcsb
Sep 1, 2015 10:17 AM
superchomper2003
Aug 26, 2015 09:39 AM
GRRR65GTO
Jul 10, 2015 08:27 PM
Breitling
Jul 6, 2015 06:39 PM
Breitling
Jul 6, 2015 04:50 PM
