Front struts under LCA?
Old Aug 10, 2018 | 08:22 PM
Northeastconfederate's Avatar
5 Year Member
Default Front struts under LCA?
I saw another thread in which someone mentioned installing the front struts with the lower mount UNDER the front LCA's in order to lower the front end. Is this safe? Anyone running their front struts (on a 2wd truck) like this? Seems like a cheap way to lower the front end (though it will require an alignment); but in that confuguration, all the weight would be carried by 2 bolt heads on each side. That seems like a bad idea to me.
Old Aug 10, 2018 | 08:32 PM
FFDP's Avatar
People do it, but I don't like it either. Most tend to buy grade 8 bolts that will handle far more stress.
I did coil relocators that move the spring perch down on the factory strut up to 2in. Of course this requires a spring compressor to remove the top hat and everything else. Or just buy lowering struts and swap over your factory coil.
Old Aug 10, 2018 | 09:07 PM
5 Year Member
Thanks for the input. Didn't know there was such a thing as adjustable lower spring perch. Might have to look into that.
Old Aug 11, 2018 | 11:19 AM
Atomic's Avatar
I have a gauge for that
What year?
Out1aw
Apr 23, 2007 10:52 AM
IMD
Apr 21, 2007 05:02 PM
MR Marine
Sep 24, 2006 03:48 PM
Sport Side
May 16, 2005 12:20 AM
