Forced induction guys using Circle D 278mm converter
Old May 16, 2014 | 12:05 PM
  #21
03sierraslt's Avatar
All I did was show you how to set it so it wouldn't lock under higher load.
Old May 16, 2014 | 12:10 PM
  #22
timmay208's Avatar
correct. appreciate all your help to btw
ive been messing around with my partial throttle stuff on shifting, at times its shifting into 4th at like 30mph and rpms are way low so im trying to figure all that out without messing other things up
I have my edge CTS for display and it has a throttle % ive been watching it vs speed to see where im at. Thing i found funny is at a stoplight its showing like 15 or so % TPS, seem strange as my foot is not on the pedal at all
Old May 16, 2014 | 01:51 PM
  #23
Funkster's Avatar
12 Second Club
Electronic throttle bodies do weird stuff like that. It is normal.
I have my converter set to lock up only in 4th and only at 70+ MPH. When I am going to play around I always downshift to 3rd or 2nd to be easier on the trans as well.
Old May 16, 2014 | 01:58 PM
  #24
timmay208's Avatar
if i understand right my converter should be locking up at 40ish in 3rd around 48 in 4th but its still not locking till about 55 in 4th. Im still trying to learn how all these maps work so i could be reading stuff wrong
Old May 20, 2014 | 02:41 PM
  #25
Skip Fix's Avatar
Circle D must have had some changes since the 90s as I see a lot of good results from them npw. I had them redo a TH 350 TCI for me for my 400 HP Pontiac motor. After some street miles and maybe 75 1/4 mile passes laid over about 1/3 of the fins on the inside.
Old May 21, 2014 | 06:57 AM
  #26
Circle-D's Avatar
Former Vendor
Yes, we have improved a lot in the last 20+ years, we are always improving. Swing by and check us out, I think you will be impressed.
Chris
Old May 22, 2014 | 05:56 PM
  #27
Skip Fix's Avatar
Thanks for the response Chris. Having laid over that many fins with a mild setup and saying it was to also be a race convertor was disappointing to say the least.
I will say locally had worse results with TransKing on convertors.
Still on Hempstead Highway?
Old May 24, 2014 | 10:34 AM
  #28
Circle-D's Avatar
Former Vendor
Yes, Hempstead and Fairbanks. Not sure what we did on the TCI back in the day and sorry for the problem.
Chris
Raggedz71
Jul 29, 2016 10:20 AM
Silveradorst07
28
Apr 3, 2016 02:56 AM
Silveradorst07
Dec 31, 2015 12:04 AM
KyleW707
Jul 29, 2015 08:17 AM
black6spdz
Jul 16, 2015 01:32 AM
