FLT L7 Install / Tru Cool 40K / Bud Hayes3 rocks!
Old May 30, 2010 | 11:03 PM
  #41
SnakeOiler's Avatar
Glad to see you got the 45° hose ends. good choice.
You need 2 of these at trans. They're 1/4 pipe - (-6AN) adapters. Thanks Snake Oiler for info!
Hey, I thought I told you NPSM, not NPT. I would have used these. Or preferably, ones with an O-ring seal
Old May 30, 2010 | 11:07 PM
  #42
FLT's Avatar
FLT
FormerVendor
Those are the ones we stock with the brass washer. They work great.
Old May 30, 2010 | 11:37 PM
  #43
skolman91's Avatar
Geez and i thought i had a rusty frame, mine looks like a show truck compared to yours..
Old May 31, 2010 | 12:21 AM
  #44
HoveyBayou's Avatar
so, where are the donut vids? they are irresistable with a stall.
Old May 31, 2010 | 07:15 AM
  #45
fastnblu's Avatar
Snake or Vince, what's the diff betw NPSM or NPT?
It's what guy at the fitting/ hydraulic store recommended. I said what bout O-ring? He said not needed. Andy said I shoulda told u I was goin AN so u coulda installed them instead. It was a late in the game decision to go AN.
Vince, is that index washer, for lack of a better term, the only diff.?
skolman91, ya I love how MI road salt just uglies up underneath & leaves a rusty frame. It's yet another advantage to living down south.
HoveyBayou, no donut vids. No vid cam. ...Yet!
Old May 31, 2010 | 03:06 PM
  #46
1Bear's Avatar
NPSM National Pipe Straight Mechanical (straight thread)
NPT National Pipe Thread (tapered thread)
NPSM fittings are typically used in hydraulic systems.
Old May 31, 2010 | 03:50 PM
  #47
fastnblu's Avatar
I knew what NPT stood for. I just couldn't come up w/. what NPSM stood for, yet I knew I needed a 1/4" straight.
You by chance a machinist?
Old May 31, 2010 | 05:49 PM
  #48
1Bear's Avatar
No, I've just had my hands in a lot of different things. Before becoming a welding inspector, I ran the equipment department for a construction company and of course my early background was an instrument fitter. In my spare time I would build off-shore race motors and good faith re-builds on hurt crate motors for a local GM dealer when I lived in Norcal, which just about all were big-blocks of course.
Old May 31, 2010 | 07:33 PM
  #49
FLT's Avatar
FLT
FormerVendor
No it is another form of seal for the fitting to case. I have never seen an oring for these so that's new to me. The brass washer is a bit funky because it kind of floats around before you totally tighten the fitting up. Does not fit tight on the threads as one would think it should I guess is what I'm saying.
What I normally do is us a bit of anaerobic sealer on the threads. Then tighten the fitting up holding the washer on center as best as I can. When the shoulder of the fitting comes in contact with the washer and the case I now have double seal. Works well for what it is.
I'll have to get my hands on a set with the orings to see if I like those better. They use the same concept for the rear cooler fitting on a 97 and later 4l80e. The only difference is the pressure on that fitting is directed right into the center support. Not sure how this will work when the actual hole the threads go into see's pressure.
Old May 31, 2010 | 08:03 PM
  #50
fastnblu's Avatar
Anaerobic sealer? Is pipe dope (liquid teflon paste) fall under that category? I was gonna use pipe dope or teflon tape, & my 1 brother said NO. I was thinkin the former would be better of the 2. He said u don't want issues w/. it workin loose & getting into tranny. I wasn't gonna slop it on just extra insurance against possible leaks. So I heeded his advice.
No leaks.
BTW, I may've already mentioned it, but guy @ hydraulic / fluid systems store showed me the blue fitting I went w/. after I showed him that Russell 1 you mentioned.
EDIT: Permatex 51813 = Loctite 518, or is there another 1 you use that dries in absence of o2?
Loctite 37394 is only $8 from Summit. Permatex 51031 Anaerobic High Temp Flange Sealant 1.69 fl. oz. 50 ml is a bit pricey ~$23. Even more $$ is Loctite 574 Anaerobic Sealant @ $25.
So which 1 do u recommend? For other PT members since mine is lookin the way I want it too now it's tight - DRY.
