FLT L7 Install / Tru Cool 40K / Bud Hayes3 rocks!
Old May 30, 2010 | 12:28 PM
  #31
budhayes3's Avatar
PT's Slowest Truck
Nice meats brother
Old May 30, 2010 | 01:56 PM
  #32
fastnblu's Avatar
Billy, those are for a Z06.
Now, w/o further ado. When I do a project, I try to help. PICS = 1000 words!
ProLite hose. It's not cheap!!!
But it's easy to work w/., since there's no steel braid & has a min. bend radius of 2 1/2", rated @ 350PSI, safety factor of 4:1. You'll never hit 350, say 1400 is outta the question on a trans, even in reverse. Here's most of my AN goodies, but not all. It costs a lot to run full AN end-end. Yes, some Aeroquip mixed in, but mostly Earl's.
The straight AN fittings weren't even used, nor were the steel adapters to lower right. Instead of steel, I opted for blue anodized Earl's as seen in later pic. Consider it a $100 credit, since the Summit guy claimed he knew everything I needed to do AN for trans & cooler. He didn't!
You need 2 of these at trans. They're 1/4 pipe - (-6AN) adapters. Thanks Snake Oiler for info!
3 of these. I used 2 after the 1/4-6 adapter @ trans & 1 on lower connection @ Rad. I used a 90* on the upper Rad connection. The Earl's 90* p/n is AT809106ERL.
4 of these 5/8" Inverted Flare Adapters. Thanks again, Snake Oiler!!!: 2 @ Rad, 2 @ Cooler.
Need I say more. Level 7!!!
My Poor Man's Tranny Jack. Helped to prevent slips crushin my bro or me, but I shoulda made it a hair bigger. I only measured 2 sides. The front protrudes, so needs to be compensated for that.
A billet work of art!
Lower brkt & non swivel 90*s. I do not recommend non swivel crimp-ons. It's the non-swivel part, cause it has to have hose rotated at opposite end. Spend the extra $2-3 per fitting x2.
Also, not seen is the upper brkt I made. I'm not happy w/. how the finish turned out, but I rattle-canned it instead of breakin out the real eqpt. - A spray gun woulda done a much, nicer job. Materials were recommended at a paint store I deal w/. It's on & functional, but may be modded...
Old May 30, 2010 | 02:10 PM
  #33
budhayes3's Avatar
PT's Slowest Truck
Nice Tom...hey who's the ***** wearing the gloves?
Old May 30, 2010 | 02:25 PM
  #34
fastnblu's Avatar
I let my bro know u said that. He's like 6'8 300 # of muscle. Maybe you'll meet him.
Old May 30, 2010 | 02:28 PM
  #35
budhayes3's Avatar
PT's Slowest Truck
Uhhh, I thought it was you wearing the gloves...5'10", 195#...your bro can wear pink gloves if it makes him happy (he's not coming with you to Jersey is he...if so, I'm going to Michigan!)
Old May 30, 2010 | 02:34 PM
  #36
fastnblu's Avatar
I knew who u thought it was. I use those disposable gloves but I don't wear pink.
I was just playin, he's around that height (5'10"), & not that heavy.
I'm the youngest, but I'm not 5'10", & I'm more solid.
Old May 30, 2010 | 05:18 PM
  #37
fastnblu's Avatar
IDK if that TruCool will cool everything...
Old May 30, 2010 | 08:29 PM
  #38
FLT's Avatar
FLT
FormerVendor
That looks like a small inter cooler!
Old May 30, 2010 | 08:39 PM
  #39
fastnblu's Avatar
So it does.
Old May 30, 2010 | 09:07 PM
  #40
fastnblu's Avatar
Aah Vince...
https://www.performancetrucks.net/fo...d.php?t=463319
