flip kit
Old Jul 23, 2008 | 10:57 PM
454navyss's Avatar
Default flip kit
i have a 3/4 drop on my truck with helwig overload springs on the rear which raise it about an inch (making it 3/3). i want the truck lower in the back so i was thinking about putting the stock shackles and hangers back on it, and putting a flip kit and c-notch on it with shock mount extenders (i think thats what they are called) which will set the truck at about a 3/5 drop (making it sit level). am i on the right track or is there a better way to retain the trucks current payload (or increase it) and lower my truck more?
Old Jul 24, 2008 | 12:30 AM
L7 Sierra's Avatar
Yes... I am first
You could use air helper springs. They work great rather loaded or empty. I had a set on an old 3/4 ton I had with a 5/7 drop, and I never had a problem eaither way.
I went cheap and used my air nailer tank to fill up my springs, since I spent all the money on the motor I didn't have money for the auto system.
Old Jul 24, 2008 | 08:54 AM
KevinF56's Avatar
a flip kit with stock shackles will actually get you a 6" rear drop. to obtain a 5" drop you'd need to put in 1" lift shackles.
as said above, the best way to up your payload with a flip kit would be to put in helper bags. that way you can adjust how firm or soft it will ride depending on your payload.
Old Jul 24, 2008 | 11:29 AM
454navyss's Avatar
i have aftermarket overload springs in the rear that raise it about an inch, maybe a little more, so with my stock shackles and hangers i should have a 5" drop. correct?
who makes a good set of helper bags? how much should i expect to spend on a set?
Old Jul 24, 2008 | 05:37 PM
02BlueStepside's Avatar
Flip kit, lift shackles, and helper bags should do the trick. You could just skip the lift shackles and put a little air in the helper bags to lift it up to a 5" drop. Air lift and Mcgaughy's both have helper bag kits many people use.
How do the overload springs you have attach? They may still raise the truck, or depending on how they are attached with the flip kit they may lower the truck more.
Old Jul 24, 2008 | 09:07 PM
454navyss's Avatar
they attach right to the top springs with u-bolts. they raised the truck about an inch in the rear when i put them on. so instead of it being lowered 4 inches in the back (2" shackles and 2" hangers) it is only lowered 3 inches
GXPJAY
Feb 13, 2022 08:15 AM
GXPJAY
Nov 5, 2015 06:49 AM
YenkoST
Aug 28, 2015 01:42 PM
323steel36
Aug 25, 2015 05:11 PM
