Encoder motor for 2005 Z71 problems
Old Oct 14, 2012 | 05:24 PM
bruno17's Avatar
Default Encoder motor for 2005 Z71 problems
My encoder motor on my transfer case is out for the third time. It went out at 18,000, 48,000, and now again at 92,000. Both times gm covered it. After talking to the dealership, I suspect they are going to cover it again. My issue is, this part should not have to be replaced this often. I use 4wd rarely and autotrac on occasion. Has anybody else had these issues?
Old Oct 14, 2012 | 05:49 PM
scooter k's Avatar
What's the actual problem? Service 4wd light? Any codes?
Old Oct 14, 2012 | 06:33 PM
whitedakota's Avatar
I just replaced mine for the first time on my truck at 154,xxx. Truck is a 2005 also.
Old Oct 14, 2012 | 06:36 PM
I replaced mine with a gm reman from the dealer.
Old Oct 14, 2012 | 08:16 PM
bruno17's Avatar
Lights on push buttons went blank and service 4wd light came on
Old Oct 16, 2012 | 10:32 AM
scooter k's Avatar
It's probably an encoder sensor in the encoder motor that could be bad. Had a lot of these but also wiring issues from the encoder motor to TCCM. Also terminal tension issues at both ends. Repeated failure like that usually doesn't happen. I'd be looking into it more.
TXsilverado
Nov 26, 2015 10:54 AM
CammedZ71
Aug 2, 2015 01:44 AM
mrgrim
Jul 8, 2015 08:12 AM
