EFI Live segment swap for 4L80e conversion
Old Sep 26, 2008 | 09:45 AM
Superado's Avatar
11 Second Truck Club
Default EFI Live segment swap for 4L80e conversion
how?
available file found where?
current OS 09381344
this is the only missing link left in my conversion...
well...
except for cablebandit and quicksilverado
Old Sep 26, 2008 | 10:05 AM
kbracing96's Avatar
Just go to Holdencrazy.com and find a truck with the same os as yours, the engine doesn't mater, as long as it has the 4L80e tranny and your os. (I just looked and there is a 2000 Silvi with one). Load your current tune as the primary and the 4l80e tune as the compare, then just to a trans segment swap and you should be good to go.
Old Sep 26, 2008 | 10:12 AM
Superado's Avatar
thanks!
is there any reason why I should change to a later OS?
Old Sep 26, 2008 | 10:38 AM
kbracing96's Avatar
I wouldn't, if anything I'd go to a COS3 or 5.
Old Sep 26, 2008 | 10:41 AM
Superado's Avatar
oh...I thought I wasn't able to go to a COS w/ the 2000 pcm...
Old Sep 26, 2008 | 10:47 AM
nonnieselman's Avatar
COS5 FTW... i still need to do this...
Old Sep 26, 2008 | 11:57 AM
kbracing96's Avatar
It's not the PCM, I think that you would just have to upgrade to a different base OS and then go COS from there, but I haven't looked into it for a while. IIRC you have to cut and past all the tables from your os to a newer one and then upgrade to the COS, not really hard, just takes a little while. If I was going to do it, I would use the OS that can be upgraded to COS5.
XL7
May 5, 2022 01:48 PM
lo&sloSierra
Aug 30, 2015 02:36 AM
creekrat
Aug 2, 2015 01:27 AM
lxcoupe
Jul 14, 2015 10:14 PM
