Educate me on stall's
Old Jan 5, 2007 | 05:39 AM
In Need of Cup Holders!
Default Educate me on stall's
Ive never owned an automatic worth a damn so Ive never had a clue about those funny looking stall converters. I have an 03 Silverado 5.3 and Im looking for something a little mild, but enough to make a decent difference.
I'd say what I think stalls do, but Im sure Im way off so I wont even waste my time. Any help/links are appreciated!
Old Jan 5, 2007 | 08:30 AM
bgray's Avatar
TOTM: June 2007
alright..basically a stall enables a automatic transmission to slip to a certain rpm..like reving it in neutral like a manual.
good streetable stall goes from anywhere to 2000-3000..alot of guys are running 3000 stalls around here with a big cam...if you want something mild meet half way with a 2600. Also recommend getting a mild cam if your gonna be doing a stall...performance will leap bounds.
Old Jan 5, 2007 | 08:37 AM
TXsilverado's Avatar
2600 is a very mild stall. i have one and recomend atleast a 3000. 2600 acts too stock for me.
Old Jan 5, 2007 | 08:47 AM
NBred94's Avatar
Another relevant issue is heat. With the increased "slip" inherent in a higher stall speed, you will generate more trans killing temps, so an external cooler (or a bigger one) is usually recommended. This goes double if you tow with your truck. Generally, all else being equal, higher stall speeds = higher temps.
Old Jan 5, 2007 | 09:11 AM
So it basically makes the car idle higher? Or can you still run it at stock rpm's while dd'ing it.
Old Jan 5, 2007 | 09:26 AM
KY_BOB's Avatar
Idle isn't changed. On acceleration it will allow the engine to spin up to a higher rpm before pulling. At the higher rpm, the engine is making more power, thus a stronger launch.
Make since?
Old Jan 5, 2007 | 09:46 AM
NBred94's Avatar
Cruising down the highway will not change either. When the converter locks up, the fluid coupling changes to a mechanical link, so changing the stall speed only makes a difference during acceleration or at lower speeds/gears where the converter is unlocked.
Old Jan 5, 2007 | 12:08 PM
Silver-Dollar's Avatar
A torque converter is a fluid coupling/pump linking the engine to the transmission. The higher the stall speed, the more the engine builds rpms before applying pressure to engage the transmission (driveline). Every torque converter has a stall speed. That is why, in an automatic, while in gear, the vehicle does not stall out when you come to a complete stop.
Old Jan 5, 2007 | 12:36 PM
RandomHero's Avatar
think of it like a mac truck you hear on the road. When it's at a stoplight and the light turns green, you hear its engine acccelerate but it doesn't go anywhere until a certain rpm is acheived. A stall is just like this. Under mild acceleration it won't go to it's rated rpms(lets say a 3k stall) it might go to 2200 before you feel your truck start to move.
Old Jan 5, 2007 | 01:40 PM
86MC_SS's Avatar
http://auto.howstuffworks.com/torque-converter.htm
wickedRCSB
Oct 30, 2015 09:45 PM
Miguel199
Oct 16, 2015 08:04 PM
Wolftrk99
Oct 2, 2015 08:17 AM
bisqikss
Sep 27, 2015 09:40 PM
sTNT971
Sep 26, 2015 06:27 AM
