Drop questions?
Old Oct 7, 2005 | 11:33 AM
BIG Newton82's Avatar
My '03 has the two inch drop springs up front and the 3" drop leafs. Rides pretty decent... but still bottoms. Can get the kit from Ground Force... the leafs just make it a more simple and less time consuming install.
Old Oct 9, 2005 | 01:25 AM
blue 01's Avatar
2 by 4 DJM with LCA. Air lift air slam helper bags an back so you want bottom out. I am even using cheep toxic shocks and the ride is still great.
Old Oct 9, 2005 | 08:42 AM
skindog39's Avatar
I'd go with a 2"-4" drop kit from DJM suspension. I have heard good things about them.
Old Oct 10, 2005 | 04:01 PM
smooth sierra's Avatar
I just finished up my 2/4 mcgaughy's this weekend. It was a breeze if you have the right tools. ie....air compressor and an air chisle for the rivets the front spindles are a cake walk. The ride is perfect.
I had a problem with bottoming out on the rear also. I installed new nitrogen gas shocks this weekend. No more problem. I suggest anyone having a problem with a 4" drop try some good shocks before notching the frame. I personally got some kyb shocks and am quite happy with them. It is important to buy a dropped shock. The factory shocks just don't work well when compressed that much.
Old Oct 16, 2005 | 11:58 PM
Pjstucn's Avatar
Make sure u get the shocks, i dont care what company or how much you drop ur truck, it still makes a diference. Also make sure u get an alingment afterword.
Old Oct 17, 2005 | 12:42 AM
dust6928's Avatar
not trying to hijack the thread but who all has had to do the carrier bearing kits with their drops? if you did how much of a pain was it to do?
Old Oct 19, 2005 | 12:35 AM
urr2slo's Avatar
For A Factory Ride The Mcgaughy's Is The Way To Go, For Ultimate Handling Go With The Hotchkis Tvs Setup($$$) But Worth It. I Used The Bell Tech And Have Not Been That Happy With It. I'm Running The Rancho 9000 Adjustable Shocks All The Way Around And They Work Awesome, Just Need To Find The Right Length Ones For Your Drop.
Old Oct 19, 2005 | 10:43 AM
blue 01's Avatar
Easy, take a couple measurement,cut the cross member off, drill two new holes, and put bolts in.
Old Oct 19, 2005 | 11:34 AM
leochevy2001's Avatar
did you get front and rear? what were the part #'s to the shocks? where did you buy them from?
Lamartian92
Sep 10, 2015 09:27 PM
Lamartian92
Aug 21, 2015 01:43 PM
Lamartian92
Aug 20, 2015 10:35 AM
USMCvet0311
Aug 1, 2015 07:45 AM
