Driving in 4WD with no rear drive shaft?
Old Jan 3, 2006 | 03:01 PM
Drizzle's Avatar
Default Driving in 4WD with no rear drive shaft?
I have a 97 Tahoe with a 4L60 E in it and I was wondering if I removed the rear drive shaft from the tranny could it be driven on the street in 4 wheel high? This is asumming that I put something over the hole so tranny fluid will not spill out. Thanks
Old Jan 3, 2006 | 03:05 PM
vanillagorilla's Avatar
porque? I'm totally confused as to why you would want to do that?
Old Jan 3, 2006 | 03:18 PM
smooth_addictions's Avatar
if you dropped the drive shaft on the street and had no other way then i would say yes. no fluid should come out. but i dont advise that you do it for too long. plus your steering is going to go down the drain.
Old Jan 3, 2006 | 06:03 PM
spitfire2332's Avatar
yeah why in the hell would you want to do that?
Old Jan 3, 2006 | 08:34 PM
Drizzle's Avatar
well I didnt say because I figured you guys would know that I either had a rear end or drive shaft problem. I have a broken ring and pinion and I have already driven the truck on the street in "front wheel drive" in 4 wheel high but the pinion bearing is bad and the head on the pinion is broken off so anything above 35 mph is shaking really really bad. It started by me getting on the high way. I could go up to atleast 45ish before fine in 4 wheel high with the back end not engaged. Thanks
Old Jan 3, 2006 | 09:53 PM
Wilde Racing's Avatar
How do I change this text
I drove my truck for about a week in front wheel drive when my G-80 gave up, I just removed as much of the broken crap I could out of the rear-end, left the rear drive shaft in, and also replaced all the bearings in the rear-end too.
And talk about torque steer............................
Old Jan 4, 2006 | 05:38 AM
silver-mod-o's Avatar
Hunt&Fisherator
I did it countless times home from the mudhole.... breaking axles, gears, driveshafts, u-joints,.... you name it... I wouldnt do it much but its good just to get you home.
Old Jan 4, 2006 | 09:07 AM
You guys are crazy!
Old Jan 6, 2006 | 11:53 AM
44-40 sixgun's Avatar
Yes I've done it just to get home.
Old Jan 7, 2006 | 12:36 AM
hey that would be fun then maybe you could be as fast as those ricing (i mean racing)
hondas out there j/k
