Driveshafts
#35
Hmm why is too short when the new trans is longer
It only makes sense with a 1-piece DS. If it was longer, the yoke would be too close to tranny or binding. This is not the case.
Do you still have you stock 65E trans? Measure it from the bellhousing to the tail. Do the same on the 80E. I bet the 80E is shorter by 1-1/2" to 2" overall.
Jim
#38
Originally Posted by Dub Silverado
There are different shafts for the 80e and i have measured both of them. The 80 is nearly 2 inches longer.....
None of this would make sense if the 80E is longer from bellhousing to tail end.
Possible incorrect yoke?
Jim
#40
Is your truck in the air when you're looking at it? It needs to be sitting on level ground before you make measurments. It makes little to no sense that a longer tranny will cause you to have a shorter driveshaft.
According to online sources
an 80E is about 32 11/16" long and an LS1 style 60E is 31 5/32" long. Either way you hack it, the driveshaft should be too long....but....what do the two yokes look like? I assume you switched yokes, and it appears that the 80E yoke might be considerably shorter. If it's the same as a TH400 yoke, then they make longer ones.
