Driveshafts
Old Dec 12, 2006 | 06:58 PM
  #51
are u a sb or rb, like 6.5 or 5.5 cuz my dads 2500hd has a once peice on his CC 6.5' bed.
Old Dec 12, 2006 | 07:29 PM
  #52
Dub Silverado's Avatar
I have a 5.5 foot bed i think its 5' 8" to be exact. Let me know the length on that sucker if you can.
Old Dec 12, 2006 | 08:11 PM
  #53
That sucks Dub. I mean really sucks. That just don't make any sense. The tranny is almost 2" longer than the stocker.... the 80E yoke looks to be about 2" shorter..... My math is not the greatest, but that combo should work.
I mean, did your wheel base grow on you? Did someone swap your DS without you knowing?? Hell, I just dont understand. I'd be pretty frustrated myself.
I think you should do a little more research on different 80E yokes before having a different DS hacked.
Have you ask Chuck or Vince at FLT about this? They might have an answer.
Jim
Old Dec 12, 2006 | 08:13 PM
  #54
I have not talked to them yet. The problem with adding another yoke is that it will only add length to the end that goes in the tranny. The problem right now is that the yoke is holding the u joint way farther out of the tranny than it should be. It should be right up agains the tailshaft almost but mine is nearly three inches shy of that. The only way to move it back up is to add to the driveshaft.
Old Dec 12, 2006 | 08:17 PM
  #55
Who says the u-joints have to be right up against the tranny?? I don't really see why that would need to be, but then again, I'm no tranny or u-joint expert either..
Jim
Old Dec 12, 2006 | 08:19 PM
  #56
They say that the farther they stick out the more vibration you will get. Even if you cant feel it, it will tear up the tailshaft in no time. Every good drivetrain shop i have talked to said there should be no more than one inch of shaft haning out then you ahve the u joint.
Old Dec 12, 2006 | 08:32 PM
  #57
That could be because most that would stick out that far probably are not far enough into the tranny. If you had a longer yoke that went into the tranny as far as it needed to, then I bet it would be fine. IMO.
Jim
Old Dec 12, 2006 | 08:35 PM
  #58
Lightbulb
Here are some pics of the parts.
Stock(Top)
80e Bottom
How far the new yoke goes in when the driveshaft is connected.
How far it should go in with the correct driveshaft length.
Look closer my friend. The stock yoke has that spacer that makes it look like it's in much further. Imagine the spacer gone, then tell me what you think.
Just an observation.
jim
Old Dec 12, 2006 | 09:08 PM
  #59
BigCountryx's Avatar
My HD has a 2 piece shaft, but this is how much yoke is in my stock 80e
Old Dec 12, 2006 | 09:14 PM
  #60
That is the exact picture I was looking for. Thank you so much. Now i know mine is not right.
