Driveshaft Loop (Pictures)
Old Nov 11, 2006 | 01:59 PM
1TRUESS's Avatar
This is what I used and bent it to fit the cross member. I need to find a better way to mount it, because i used u-bolts around the cross member to hold it on.
Old Nov 11, 2006 | 02:34 PM
Sport Side's Avatar
a bolt in setup would be nice.
Old Nov 17, 2006 | 11:25 AM
silver-mod-o's Avatar
Hunt&Fisherator
That little area of weld isnt going to hold if that driveshaft takes a dump.
werd... I dinged my DS and cross member and gas tank when mine went... better safe than sorry. especially when you have that kind of rotating mass under your *** at that many RPM's....
Old Nov 17, 2006 | 12:44 PM
95ImpSS's Avatar
formerly 1BADC10 (12/14/2011)
I would just hate to see it take out your tailhousing on teh trans...
That part alone is ~$80... been there, done that. I need to look into that. Luckily when my tailshaft housing broke & d-shaft bent (slightly), the yoke stayed in the trans. Was going 95mph when it happened. Lucky me, huh?
Old Nov 17, 2006 | 05:32 PM
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
Problem is when the tailhousing breaks it quickly dumps all the fluid in the trans and will make quick work of the planetaries and gears with the heat of hauling *** down the road.
Old Nov 17, 2006 | 09:16 PM
dirt track racer 81's Avatar
we had a guy that wanted to put this on his cobra a while back and it wouldnt fit so he left it with us sayin its no use to him, when i get my trans back in, ill be installing that
Old Nov 17, 2006 | 09:47 PM
YenkoST's Avatar
Not the prettiest but it'll work..great job....I need one after seeing my dad's ex suburban drop its driveshaft and kill a Corsa exhaust. I think it he would have notched it out then fully welded it to the crossmember...that would be very functional and a nice setup as well.
I can't decide if I want to use straight bar or round bar for my loop. I'll probably go straight bar since it looks better.
Old Nov 17, 2006 | 09:50 PM
Toaders's Avatar
If you have a hugh speed failure that thing will be like a fart in a wind storm. IMO
Old Nov 20, 2006 | 08:50 PM
Question
Does anyone make a bolt in DS loop for our trucks?
Jim
Old Nov 21, 2006 | 09:45 AM
FarmerBeau's Avatar
Sexy Party Mod
How wide are those loops? I have another one of those aluminum peices of **** on order and i know im gonna break another one.
thompson
Dec 27, 2017 06:48 AM
OHsixLS3
Nov 22, 2015 07:45 PM
turbo6c3
Oct 5, 2015 06:11 PM
jscherbs
Sep 30, 2015 07:54 AM
Wrecker 426
Sep 29, 2015 11:00 PM
